#19 | |
#20 |
vacuum sucks, simple as that. There is a difference in pressure on the ends of each hose, so the PCV system works as a kind of restricted bypass
#21 |
![]() ![]() ![]() Drives: 09 yaris Join Date: Mar 2009
There are 2 hoses.
#1 goes form the PCV valve that is screwed into the crank case to the intake. #2 goes form the air intake to the crank case. In the red box is #1. The black fitting is the PCV valve. In the green box is where #2 should be. With a stock car this would only see clean air.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week. |
#22 | |
where did you get this information FORM?
#23 |
I guess I can’t spell after 11:30 at night after being up all day and drinking a few.
#24 |
やりすぎだ~
What is the inside diameter of the hose that you're connecting it to?
I might do the same, but need to know the inside diameter |
#25 | |
toyota
#26 |
I had a small length of 3/8" [I think that's the size it was] tubing I put on the filter then put the ventilation hose around that with a zip tie, there's a lot of stretch in that hose once you cut away the protective wrap. But the filter does have a very small inlet and outlet so instead of zip ties a screw clap might be an easier solution.
#27 |
toyota
anyone confirmed the 5psi drop for using the filter is that affecting any hp at all..
#28 |
It should not, that PCV section is basically just a bypass, any air that is slowed down there will just go through the main intake tubing...
#29 | |
what psi drop are we talking about? i guess i should have read the rest of the thread.
#30 |
toyota
ok thanks etimago..im on this.
psi drop due to oil filters.. which mean itll slow down the air going in the intake but as etimago said wont make a difference. |
#31 |
psi drop where? where is the psi drop?
#32 |
toyota
#33 |
5psi drop at what air flow?
#34 |
toyota
the excess air coming from the engine thats being recycled back to the intake. that air is whats being filtered due to oil that goes along with it. i could be wrong though so check with the person that did this already im still in the process.. |
#35 | |
the minimal air coming out of the valve cover is not going to cause a 5psi "drop" in this filter. i'd imagine you'd see no drop at all actually.
#36 |
toyota
i guess that only apply for air compressors...so i guess it has no effect then..
| $30 Oil Catch Can, DIY | Ogredude | DIY / Maintenance / Service | 79 | 05-13-2011 11:05 AM |
| perrin oil catch can | staypuft | Performance Modifications | 3 | 11-16-2008 12:20 AM |
| OIL CATCH TANK increase performance? | 33lam | Performance Modifications | 29 | 11-11-2008 01:08 PM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
