Just installed K&N CAI
I spent the extra cash and installed the K&N Typhoon CAI the day before on my 09 Yaris and today the check engine light came on. Does anyone know why this happened since K&N claims that it shouldn't? BTW I thought the car got loud with the TRD Sport Exhaust, but now when you stomp the gas it gets really loud and throaty. Really cool!!
Check all the hose clamp's and connections for air leak's.
did that, all is tight
![]() ![]() ![]() Drives: Blazing Blue Liftback Join Date: Oct 2008
check the maf sensor you probably got a little dirt on it.
Checked K&N website for support and it suggested that the difference in air density caused the check engine light to trip and to clear the light and wait and see if it comes back on. So, I cleared the light and so far it has not come back on after a day of running errands.
![]() ![]() Drives: yaris sedan 2NZ-FE Join Date: May 2007
just to be sure , does the heat shield ' s hole have a bigger diameter then the pipe
or is it just mine ?? |
Yeah, the hole is bigger. It needs to be since the engine/tube moves and the shield is stationary. Otherwise someting would break during acceleration, but I am no expert.
Light came back on today, on the way home from work. Thinking I wasted my money. I need to check with K&N tech support.
#9 | |
![]() ![]() ![]() ![]() Drives: 2006 yaris Join Date: Oct 2008
Which diameter, the filter itself? What cel issues? I should have researched this a little better.
the diameter of the pipe itself
this may sound stupid but isnt the K&N SRi designed for sedans only ?
I have the CA no SR version. The kit came with a reducer so that the pipe would fit on the carb. K&N website states that the CA fits all.
I talked to a K&N tech and he said that it could take about 100 miles before the ECU will adjust for the increased air flow. He also said that because this model, Typhoon, is new that the state has yet to test it so it will pass smog. It can take up to 2 years before all the paper work gets done and then they will send me the sticker which allows it to pass the smog test. This is a visual fail only at this time, not a emissions fail.
#15 | |
did you disconnect the battery after installing it? my dragon throws cel when swichting from stock to sri without resetting the computer. after i disconnect the battery for about 15 mins its fine.
Does K&N state that system is compliant with the 2009 Yaris?
Last summer K&N told me that the Typhoon was only certified up to the 2007 models and that if installed on my 2008 the warranty wouldn't be honored as they had not yet verified/tested it on the 2008 models. Honestly, I'd be surprised if they have tested on 2009's already. And yes, the 2007 LB and sedan applications were identical.
Mr. 155 and climbing
'nother reason why I am glad that I went with the AFE, plus it is cheaper. Best of luck.
| installed the K&N SRI on my 1.3 sedan :) | JapRulezz | Performance Modifications | 2 | 06-27-2009 12:27 PM |
| Divorce sale: Fujita CAI $125, bixenons $140, NST crank/WP pullies $85, 17" wheels | Carvin'07 | Items for Sale by private party | 32 | 05-11-2009 11:42 PM |
| just installed cai....but... | SweetRS | Performance Modifications | 6 | 05-05-2009 08:09 PM |
| TRD CAI & TRD Qiuck Shift | Polar | Items for Sale by private party | 7 | 08-02-2007 07:03 PM |
| Installed K&N Drop in. | Motorhead6T5 | Performance Modifications | 3 | 06-18-2007 09:11 AM |
