#19 |
Who said Yaris was slow?
Does TRD makes dogbones for the Yaris? I know they had the other mounts. Pictures please!! |
#20 |
First time to the track I missed second 4 times out of 12 or so runs. My theory is that the engine was bucking around too much and throwing the linkage out of alignment. After installing the damper I got from Garm I only missed second once in 12 runs. Not bad on a stock clutch.
So yeah, the torque damper does help, both with getting power to the ground and keeping your cables where they ought to be. |
#21 |
@Castrex:
TRD Rollstopper: ![]() TRD motor mounts: ![]() I have various other TRD bushings I also received for the Yaris.
#22 | |
Start another Oil Thread!
that's a gorgeous part Garm. i find it sad that "TRD" went to all the effort but didn't do urethane inserts though :(
you nailed it sir.
#23 |
hmmmm i want these ic ant stand how much engine movement our cars have. I thought i had a broken motor mount and had another tech in my shop check while i pushed on the gas witht he foot on the brake. but no our engines just have that much excessive movement because of the crappy mounts.
#24 | ||
you nailed it sir.
#25 | ||
1NZ-FE
the grill part is just an extra bro
. ![]() DC Sports Header, Vibrant Hi-Flow Cat, Round Magnaflow Muffler, Vibrant Tip, Dunlop Direzza 195/50 Rims 15", Injen Technologies Cold Air Intake, NST CR-Lite crank, waterpump & alternator pulleys, Tanabe NF210 Springs, NST SSK 1 & 2, NST Shifter Cable & Cage Bushing Kit, Nitto Engine Torque Damper
#26 | |
I would consider changing the dogbone but one that is not too sollid. Kinda a middle ground. |
#27 | ||
yes. the reason it's purchased most of the time any. car show points lol.
you nailed it sir.
#28 |
I just picked up a TRD dogbone from Garm!!
Is cheaper than the urethane beatrush one and I hope it will provide a mild improvement over the stock bone... I've read reviews about the full urethane one and accoridng to a couple of people it was a bit to hardcore for every day use. Last edited by CASTREX; 07-09-2009 at 07:38 PM. |
#29 |
I'm putting one in my car too. More ordered and on the way -- I intend to stock a bunch of TRD mounts and bushings.
#30 |
please post reviews of the trd mounts once they are installed i may have to put this on my list of mods to get
#31 |
I see you're smoking a tiburon in the photo. Did you actually beat it down the track?
#32 | |
1NZ-FE
it was a stock V6 tiburon
#33 | |
you nailed it sir.
#34 | |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
#35 |
![]() ![]() Drives: Base 09 White Yaris 3DR 5MT Join Date: Mar 2009
Kind words once again form Tamago!
Proud to purchase parts through
#36 | |
never said anything unkind about the OP did i? ;)
you nailed it sir.
| Dash Kit - No Mods | barryware | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 09-14-2014 04:59 PM |
| Suggestions for $300-$400 worth of mods please! | CtrlAltDefeat | Performance Modifications | 51 | 01-05-2011 10:15 AM |
| Mods on an automatic sedan? | naix | Performance Modifications | 19 | 12-10-2009 11:30 AM |
| Mods Please Read! Regarding Paint Topic... | silaypalmer13 | General Yaris / Vitz Discussion | 30 | 05-10-2009 06:31 PM |
| Performance mods that won't affect/will hardly affect gas mileage?? | Mr.Yaris | Performance Modifications | 15 | 07-30-2007 01:32 AM |
