#28 |
![]() ![]() Drives: 2009 Yaris 3dr Join Date: May 2009
Okay I'm going to take the Rvers side of this. If you were at the back wheels of his tow vehicle you were basically in a blind spot. If you were 4 to 5 car lengths behind him when he signaled why couldn't you wait?
Had a similar situation last summer. Du$$A$$ was more than 6 car lengths behind before I signaled and begun moving to the passing lane to avoid rear-ending traffic entering from the on ramp. DumbA$$ went to the shoulder to attempt to pass me even though I was in the passing lane completely. Du$$A$$ missed the oncoming bridge rail by about 4 inches and only because I braked hard to let him back over. I decided in a split second that seeing Du$$A$$ splattered wasn't worth the paperwork. Dum$A$$ were clearly exceeding the posted speed limit. Best of all Dum$A$$ was pulled over by CHP 10 miles further down the road. Now I admit that naming the other driver du$$A$$ is probably unfair. But how else do you describe someone who risk a 2,300 lbs vehicle against a 26,000lbs vehicle. The worst I would have seen was $4.000 to $5,000 in fiberglass damage paint and maybe a fromt end alignment on the Motorhome. I would have driven away from the scene in my toad. The other vehicle occupants would have been airlifted or DOA at the scene. While the Yaris has sprinter speed and quick suspension you will lose every time against the brick wall. .....And as far as I can determine the Yaris vehicle registration gave me no more or less rights to the passing lane than the motorhome registration. From the pic you posted I say you were lucky. Last edited by 2009Toyotoad; 07-10-2009 at 04:29 PM. |
