Old 07-13-2009, 03:15 PM   #3
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
Wouldn't a lighter rear end "break free" earlier in a turn allowing less under steer even if the higher weight is in the front? This if the front is allowed to grip more with less overall stiffness compared to the rear.
I've always liked a lighter stiffer rear end.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
