Old 07-15-2009, 08:46 AM   #1
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
The biggest change will happen when you change your driving habits to feel comfortable at lower throttle applications.
Old 07-15-2009, 02:26 PM   #2
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
I strongly agree with this statement.
Your mpg scores are acceptable. It beats the posted EPA FE for the Yaris.
aca72 is offline   Reply With Quote
Old 07-16-2009, 03:22 PM   #3
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Agreed... The kys is to accelerate to speed, then back off slightly on the pedal just enough to maintain the speed. It's easy to do if you have a scanguage, a little harder without one. That alone probably saves me 15-20% in efficiency.
For driving on roads other than highways I limit my throttle position when accelerating to 23 as best as I can. As soon as I reach cruising speed I back off as much as I can (determined by terrain, speed, and wind). If driving 40-45mph I can usually back down to 20 on the throttle. If doing 35-40 18 or 19.
I just changed my drive route to work... doing 55-65 on a highway hardly allowed me to get much over 40mpg.... Now i'm doing non-highway which ranges from 20-40mph with stoplights every 1/3mile and been getting 45-50mpg (though it takes 5-10 minutes longer).
I figure if I drive to & from work on this route everyday for a whole tank... my tank avg should go up 2-5mpg. which would save me approximately 1 gallon of gas every 400miles.
habbits over wear in... I think wear in may have gained me 1-2mpg. Synthetic oil 1mpg max...and habbits have probably given me upwards of 5+mpgs.
First few tanks were 35-36mpg (winter)
highest tank was 45.5
Usual tank last summer was 43
Usual tank in the winter was 37-38
I'm hoping my next full tank will be around 46.
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 07:31 PM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 10:23 PM
Hmmmm noticed substantial mpg increase with nst pulley... YarisSedan Performance Modifications 11 04-16-2009 05:42 PM
Oil 5000 miles + genethekiller General Yaris / Vitz Discussion 60 02-15-2009 08:47 PM
Pure Acetone increase MPG YenOfIrrelevent Fuel Economy Forum 29 01-21-2009 10:16 AM
