Old 11-07-2006, 10:10 AM   #19
pxpaulx
Drives: Barcelona Red 5spd sedan
Originally Posted by Kitt
And actually when the engine is cold and the COOL light is on, the engine runs faster untill it reaches the normal operating temp
yeah, the cold engine light actually coincides with the RPM drop - when it gets to 1K RPM at idle the light goes off.
pxpaulx is offline   Reply With Quote
Old 11-07-2006, 10:26 AM   #20
raysem
raysem's Avatar
Drives: 2007 2-Door Hatch RS
More Coolness
Up here at 53 degrees North, the "Cool" light stays on for some time on our frosty mornings.
Threw me the first time I seen it - but I tend to ignore it now....
-- Ray --
raysem is offline   Reply With Quote
Old 11-07-2006, 02:10 PM   #21
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
what a COOL thread!
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 11-07-2006, 03:03 PM   #22
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
The FIAV is temp controled...
it's basically a throttle plate bypass.
It works like a thermostat and once it's up to temp it closes and the RMPs drop down to normal.
Old 11-07-2006, 10:05 PM   #23
regulus
Drives: yaris sedan
Originally Posted by 07WYarisRS
Running an engine as you normally would when cold will shorten the life of the cylinders, pistons and rings. (three different metals all expand at different rates)
You can drive it cold but you must drive it easy
Most cars it 130-150 degress before the lights go out or guage starts to climb.
You don't need to wait for the light to go out but you do need to drive it very easy until it's warmed up to normal operating temps(5 minutes of driving)
Lately in the mornings it takes a couple minutes for the windshild to defrost and I have not noticed much of a difference in fuel mileage with the extra minute or two.
Remember Toyota is in the business of selling cars, not handing out tips that will let your car last 1,000,000km. Driving with out any warm up is a great because people don't like to wait and it does save a bit of fuel. But it will shorten the life of the engine.
Thats why it seems like engines now days don't seem to last like the engines from the 60's 70's and 80's. Back then the old carbed engines had to be warmed up before you could drive them with out stalling or hesitating badly. These engines lasted for ever even with garbage oils back then due to the long slow warm up.
Todays engines are FAR better in design and with proper care and warm up will last 2X as long. But EFI systems allow you to drive with a stone cold engine and that shortens the life of the engine. And that's why so many engines are dead before they ever hit 250,000km.
No, too much generalization and oversimplifying.
regulus is offline   Reply With Quote
Going for test drive Monday; I'm gonna custom order one YarisBlazer New YARIS Purchase Forum 9 05-24-2007 07:52 PM
Yaris Hybrid Synergy Drive???? hasher22 General Yaris / Vitz Discussion 1 10-18-2006 03:18 AM
Wow, what a drive drell42 General Yaris / Vitz Discussion 4 06-14-2006 09:36 AM
Top 10 Cheap Cool Cars for Teens for 2006 hhcchen Off-topic / Other Cars / Everything else Discussions 21 06-04-2006 05:36 PM
07 yaris liftback and 06 xa test drive extenny General Yaris / Vitz Discussion 12 05-31-2006 11:56 AM
