#19 |
The friction point on the clutch is really far in. You have to slam it into the floor. It sounds like you aren't pushing the clutch in far enough. I doubt your synchros are going out already with that low of mileage.
#20 | |
#21 |
![]() ![]() ![]() Drives: 08 liftback 5spd Join Date: Oct 2008
another fellow that was commenting on 1/4 mile times suggested the motor torquing in the engine bay during 1-->2 shifts was changing the shift linkage angles and having a detrimental effect on his shifting. maybe the first suggestion of letting off the throttle a bit smoother would be in your favor, ideally you'd want the motor's RPM to be hanging right around the target rpm after the clutch is engaged in 2nd gear... not climbing, or dropping... i don't know a ton on the subject either, but that's my general experience with manual transmissions, on my bike, my yaris, and my friends car that badly needs a transmission...
#22 |
it's a cable. it isn't affected by minute changed in position. it's not solid linkage like some hondas.
#23 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
With the new engine and corrolla trans the problem was never encountered so far! |
#24 |
I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
Hmm I've never noticed this in mine, and I've launched it pretty hard quite a few times... When I get it out of the shop I'll have to pay close attention to see if it's doing that, and could cause it to do that if it's not...
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
#25 | |
I thought they totalled your car? --\endthreadjack and to the OP: Its not so much a problem as getting completely comfortable shifting that way, dont yank it out of gear, pull firmly untill it comes out. I had this "problem" for a while, but now I have no issues running 1st hard and shifting quickly into second once I "relearned" my shifting. |
#26 |
![]() ![]() Drives: 2007 Liftback white Join Date: Sep 2007
I had the same problem. I switched to Redline MT-90 and can now shift @ 30 mph from 1st to 2nd all day long w/out any grinding, as well as, 2nd and 3rd gears near redline.
#27 |
I have this problem running full synthetic tranny fluid for the last 30K miles. Thats life. Its probably the cocktail of short shifters I've run in the past. No way to just replace the synchros in a transmission? Excuse my noobishness. If you were going to replace a Yaris tranny what is the best option? C60? Wonder if I have the power to back up/warrant a 6 speed. I don't see why not.
#28 |
I ♥ Yaris
nope, did over $6,200 damage to it, but the insurance is paying for it.
#29 |
ヴィッツ ドライバー
Drives: 2006 3d 1.0 Linea Sol Join Date: Aug 2007
Get polyurethane (or some other, stiffer) engine mount pads.
It could just be that the engine tilts too much when revving hard and the gear linkage will sound weird due the the extreme angle of the engine. |
| New Owner - Lights on Gear Shift | javagirl | New YARIS Purchase Forum | 8 | 05-22-2009 02:23 AM |
| Reverse gear crunch | Frankd1 | DIY / Maintenance / Service | 5 | 04-13-2009 12:43 PM |
| Yaris 2007- How to Restart Multimode gear? | ronen | DIY / Maintenance / Service | 1 | 02-21-2009 05:09 PM |
| Sticky When Shifting and Sticky When Reving? | jouslee | DIY / Maintenance / Service | 22 | 01-23-2007 11:07 PM |
| clicking into first gear | tekmoe | General Yaris / Vitz Discussion | 9 | 11-01-2006 02:44 AM |
