Our off road vehicle
Drives: 2009 Yaris 3dr Join Date: Apr 2009
A humorous situation exists IMO regarding the Instrument cluster on the 2009 models that happens when marketing, not engineering drives product- a noted Toyota foible.
You can only get a tachometer in your OEM instrument cluster (persumably because it's the better grade car) on the S model. The problem is that the S model now only is available (per the Toyota website) on the 5 door hatchback which itself only comes with an automatic. Sooooooooooo........if you have a manual transmission - where you could use the tach- you can't get a tach- but if you spring for the S model- you get a tach - which is essentially useless- because it only comes with an automatic transmission! I discovered this silly situation when I attempted to buy the cluster from the 2009 S from the dealer and discovered the cluster would only be compatible with an automatic transmission Yaris! Great judgement marketing department!!!!!!!!! ![]()
| Sedan Instrument Cluster to LB Instrument Cluster | Malaya1221 | Cosmetic Modifications (Exterior/Interior) | 2 | 12-02-2008 10:05 PM |
| Instrument Cluster Swap | thepaidtraveler | Cosmetic Modifications (Exterior/Interior) | 28 | 11-24-2008 09:53 AM |
| "S" cluster in non s car? | mikenacarato | Cosmetic Modifications (Exterior/Interior) | 43 | 11-17-2008 08:45 AM |
| instrument cluster swap S -> LB | elo79 | Performance Modifications | 1 | 12-21-2006 10:22 AM |
