Old 04-21-2009, 08:24 PM   #19
Pitt Yaris
Drives: Flint Mica Sedan
What if you didn't have a pot big enough to submerge the whole piece in the pot? Would it streak or be darker in one spot than the other if you submerged half at once, then turned around and the other half?
Old 04-21-2009, 10:09 PM   #20
Yes, that would happen. Best way is an aluminum trash can or if you have a pot big enough from when you use to work at a greasy spoon and borrowed one for that special soup for the party
Old 04-21-2009, 10:45 PM   #21
Pitt Yaris
I looked at the chart/suggestions on their website about coloring. I wanna dye the outside border tan, but not sure if or how it'd work given the fact it's gray.
Old 04-21-2009, 10:47 PM   #22
That's why I chose to do a small part that would not cost much to replace. Just do as I did and pull the visor cover off and start try it. A few bucks used or from the dealer I'm sure. Would love to see other colors done since we know it works for turning them black.
Old 07-20-2009, 05:34 PM   #23
PatrickJohnson
Drives: 2008 Yaris LB
hmm, i definitely want to try this. couple questions:
would the burner of a turkey fryer be enough to heat a large aluminum trash can or watering trough to boiling?
what about the trim in the back interior around the sides? surely no pot is big enough...
PatrickJohnson is offline   Reply With Quote
Old 07-20-2009, 06:08 PM   #24
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
very good diy. should there be any note as to prep of the plastic before dipping in the dye? (clean with alcohol to remove grease, etc)
Old 07-20-2009, 06:55 PM   #25
PatrickJohnson
I'm thinking the boiling hot water would take care of that...
Old 07-20-2009, 06:56 PM   #26
Tamago
Tamago's Avatar
Drives: ZZW30
then the boiling hot water now has grease/dirt in it?
Old 07-20-2009, 06:57 PM   #27
PatrickJohnson
touche. :)
Old 07-20-2009, 07:01 PM   #28
supmet
Drives: 2007 4 Door Yaris
I kind of agree, any dirt/debris will loosen up in the boiling water and float to the top or sink to the bottom, dye will set, and you'll be left with dirty dye, but a successfully dyed piece.
But its never a bad idea to prep a piece you are dying/coloring/painting/whatevering. I'd imagine a good cleaning and alcohol prep could open pores and allow more dye to be absorbed resulting in a longer lasting dye job.
Old 07-20-2009, 07:41 PM   #29
Tamago
Tamago's Avatar
Drives: ZZW30
Originally Posted by supmet View Post
resulting in a longer lasting blowjob.
amen to that!
Originally Posted by xnamerxx
you nailed it sir.
Old 07-21-2009, 10:52 AM   #30
it will bring it to a boil. I fired up the home brew burner I have and it heated the can up pretty well. even if it does not get to a full boil, the heated water at any higher temp should do the trick
Thanks. Yes. Treat it as if you were to paint any surface by making sure debri and grease are clear from the item.
You said it
!!UPDATE!!
So far no problems fading with the two pieces in the DIY. I've left them out in the sun on my dashboard since then and no turning of colors. I wanted to double check before I moved forward with the entire trim set.
Old 07-21-2009, 06:24 PM   #31
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Subscribed. Post up pics of your "kitchen" if you ever get a chance. Looking foward to seeing the end result.
What's going to be your trick for getting the headliner to be black, eh?
Old 07-21-2009, 06:48 PM   #32
PatrickJohnson
with a big enough vat, you could dye the headliner :)
but I will probably pull it out and use fabric paint to paint it black.
Old 07-21-2009, 08:34 PM   #33
That's going to be the tricky part lol. - looked into the fabric paint as Patrick just mentioned but I don't want it to come our stiff.
I assume the headliner is backed by cardboard and preformed plastic in some areas so soaking it would probably not be good for itm
Probably recovering is still the cheapest option right now. It doesn't have to be the suade style like most have done. Just black fabric
On sale at the AC Moore or fabric store should do fine
Old 07-21-2009, 11:58 PM   #34
Sodium Duck
╚══════════RN
Yea, some of that headliner spray on glue stuff, and some fleece/whatever would probably be easiest.
Old 08-08-2009, 06:11 PM   #35
Sodium Duck
╚══════════RN
Any updates?
Old 08-09-2009, 02:41 PM   #36
Any updates?
None yet. Haven't had time during the weekends since the meet in Nashville. Hopefully in the next few weeks though.
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 01:59 PM
Painting headlight housing black need diy.. YarisSedan Cosmetic Modifications (Exterior/Interior) 5 12-12-2011 11:24 PM
diy for steering wheel change aucorium Cosmetic Modifications (Exterior/Interior) 64 06-21-2010 09:46 AM
First DIY oil change but... derickveliz2 DIY / Maintenance / Service 31 02-02-2009 12:36 PM
Black Friday Bob_VT Off-topic / Other Cars / Everything else Discussions 70 11-29-2008 08:07 AM
