Old 07-21-2009, 03:36 PM   #10
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Cool, sounds like you've got a handle on it. I'd give it another dose right after this one for good measure.
Do you have access to an OBD 2 scanner with live data? If your mileage dosn't improve after the injecter cleaning it would be worth having someone look at the O2 sensors in real time and make sure they are still "up to snuff". They have certainly served you well up to this point and are far beyond their designed life expectancy :)
I thought I heard somewhere you use the Super Tech syn oil from Walmart and OEM Toyota filters at 5k mi intervals-is this true? Whatever you're using this is a great show! I realize you put the miles on quickly but considering the number of miles this is an extremely impressive display of reliability.
TIA
R2
-The Fitful One
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
