Old 11-09-2006, 09:22 PM   #2
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
In this case where a larger alternator is not available you could add a second alternator or have the OEN re-wound for more power by a custom chop.
Adding a second alternator may require a bit of fabication to make a second Alt bracket. Where having the alternator rewound is as simple as buying a new alternator and sending it to a shop to be rewound.
But with that much power you would be very wise to run auxillary batterys with an isolator set up. Even if they are fairly small batteries. This way they charge when the car runs but will not draw a charge off the main battery.
Toyota AUX plug w/ aftermarket radio? eight_heads In Car Entertainment + Electronics (audio / video / alarm) 20 09-07-2007 02:41 AM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
