Old 07-30-2009, 01:08 AM   #23
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Chino i actually got a 2.5BAR MAP Sensor for you right here from an Audi with harness. Should be good for about 22psi like youll ever see that much!!! :P :P Very Simple, just find some place to plug it on the intake, comes with 3 Wires, should just be Signal, 5v, ground right into the connector and you should be good to go, or hopefully lol
So with the jankyness were rigging up, with the wideband, MAP Sensor, and injector harness, and soon ignition harness you should be running at the peak of your peeformance
