Old 08-01-2009, 12:26 AM   #11
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
You should never get under a car with just the roadside flat tire jacks, they are too unstable... you really need jack stands... I'm pretty sure you have to lift the car to put it on.. the weight of the car will not let you remove the bolt you need to remove to install it (I would imagine the shock might pop out and possibly hurt you)
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 02:26 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 01:46 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
DIY - TRD rear sway bar kurokoma-kun DIY / Maintenance / Service 0 10-20-2008 01:21 PM
