Old 08-03-2009, 03:25 AM   #11
AznGouki
Metsu
Drives: NCP91 ; E36
Originally Posted by NonStopTuning View Post
The NST Underdrive Crank Pulley is intended for n/a or turbo applications. This pulley should not be used with a supercharger because it would lower PSI on such an application.
You can use the NST CR-Lite on n/a, turbo, or SC applications.
You can use the CR-Lite now and keep it installed once you install your supercharger.
Perfect. Just the answer I was looking for. Looking to purchase real soon.
AznGouki is offline   Reply With Quote
