Old 08-03-2009, 12:25 PM   #30
bearda
bearda's Avatar
Drives: 2006 Mazda3 Sedan
I just noticed this thanks to its bump. The primary 02 sensor is not a raw 0 to 1 volt output, like most 02 sensors (including the secondary on the Yaris). The primary output sits on a offset voltage from the ECM, so in order to tap into it your devices needs to be able to deal with the floated voltage and if your device uses the sensor data directly, and then fools the ECM with an output, its output needs to be able to deal with that offset.
Dumb question, but if you're just adding an offset voltage couldn't you wire in a regulator for the offset? If the output is something like 3-4 V, couldn't you just hook a regulated 3V source up in series with the FIC output to bring it up from 0-1 to 3-4?
bearda is offline   Reply With Quote
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 02:03 PM
is the yaris for me? sauruman New YARIS Purchase Forum 14 02-27-2006 08:27 PM
