#235 | |
There is a small amount of up/down movement of the HU that can be realized via the 4 screws securing it to the dash assembly. Holding the HU in place with the 4 screws slightly loose, try sliding it up and down. You should notice that you will be able to raise the HU about 1/16". Give it a shot.
#236 |
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
I tried re-positioning the HU. Loosened the four screws holding the mounting brackets in then pushed up on the bottom of the HU to raise it as much as possible. While holding it up, I tightened the screws. Helped a little bit, but the gap was still very visible. So, I took that plastic trim pieces that comes with the HU and cut it up so all I had left was the piece that goes along the top edge of front of the HU.
Looks better now:
#237 |
![]() Drives: toyota yaris hatchback(black) Join Date: Jul 2009
is it possible to ship it to philippines?
#238 |
I'm all out of the ones from the group buy at this point. From the Philippines you would probably be able to order the part from a Toyota dealership in Australia (I believe that the Toyota Follow-me package is offered as an option there). If not, it's readily available from Europe.
#239 |
here again..
I have one up for grabs...US$55.00 shipped (US)...pm'd me if interested...
Don't be threating me with a good time!!!
#240 |
ah,okay.thanks for the info. :D
#241 |
dannnnnng
I can't believe I missed the group buy. I REALLY need this piece! Anyone want to sell me theirs, or start a new GB? Thanks in advance
Doug |
#242 |
#243 |
Cool, well, count me in, I'll pay right away! What other pieces were you thinking about getting from over there? I love stuff like this!
Thanks in advance for all the work and planning you've done for the forum. Doug |
#244 | |
There are a couple of people who are looking for the vertical trim pieces that would be required to use some of the Chinese HU's. Also, I am going to get a new set of center caps for my TTE wheels, and I am seriously considering getting a European RS front bumper for my 09. |
#245 |
![]() ![]() ![]() ![]() ![]() Drives: 2007 Bayou Blue!!!!!!! Join Date: Nov 2006
Post a thread of goodies available, I'm sure the GB sluts will poke interest!!!!!
#246 | |
I just want to double check that this will work for a 09 Yaris Sedan, correct? |
#247 |
#248 | |
#249 |
There are a couple of other people who had inquired about those two pieces. They are about $90 plus shipping for the two from Europe.
#250 |
Q(','Q)
is there still going to be another gb for the true Double Din Radio Trim for Liftbacks (180mm opening)?
If not are there other ways of getting the Double Ding Radio Trim??? |
#251 |
At some point within the next month I'll be putting one together.
#252 |
Yep! I am so still in on this.. No more cruising Australian eBay looking for the FollowMe trim, which never comes up
| Dash destroyed in electrical fire. | purpleminx | General Yaris / Vitz Discussion | 79 | 06-12-2009 03:53 PM |
| Double Din 180mm Trim Bezel | esyres | In Car Entertainment + Electronics (audio / video / alarm) | 19 | 03-19-2009 09:01 PM |
| [Recovered] Group Buy for Australia #1 (Badges) | harveyjai | Australia | 9 | 12-13-2008 03:59 PM |
