#1 | |
oem boosted engines are built more solid and come with lower compression then n/a cars do. and also alot of research and development went into designing the motor and plus to they have alot of years behind them doing this and i mean alot. but upgrade the rods and pistons and change oil earlier then you normally would and run necessary gauges to monitor and dont beat the crap out it everyday and it will be reliable if tuned ight of course
08 junction produce belta almost done and ready for paint 06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp 90 crx sir ls vtec turbo 755 hp mecp masters certified |
![]() ![]() Drives: 2009 5 Dr. Hatch Join Date: Jun 2009
So even a Blitz Supercharger which boosts to a relatively low PSI would decrease engine life? The reason I ask is I've been reading up about other cars and people safely giving them a relatively low boost without building the engine. Granted, the engines I've read about are a bit more performance oriented than the one in the Yaris (I've been looking at 350z's, S2000's, and Civics) but I figured that the stock engine in the Yaris had a level to which it could be safely boosted too, or is my thinking flawed?
#3 | ||
![]() ![]() ![]() Drives: Yaris Join Date: May 2009
some people do enough abuse to their oil after 1 weekend, some can go 3-4 weekends + daily driving before they "need" to change. it really depends on the setup and oil analysis is a very cheap and good idea, especially if they have a baseline of your car pre-boost. :) Quote:
good idea is to build it for 250 more horsepower then you plan to have. :) |
| Whistle at idle - vacuum leak, induction side | RichieRoo | General Yaris / Vitz Discussion | 17 | 12-16-2022 05:53 AM |
| TC swap? | MicroHB | Performance Modifications | 38 | 03-26-2009 12:39 AM |
| Induction with an Auto-Trans. | Sweet Mercury | Forced Induction Forum | 7 | 09-08-2007 03:15 PM |
| Engine mods - why bother? | RallyYaris | Performance Modifications | 143 | 12-24-2006 03:56 AM |
