#91 |
OK. I just probed mine - I see 3.94 volts on each of the SIG lines with the seat empty, ~4.00 volts with me sitting on the seat (and I weigh about 155 lbs), and ~4.20 volts when I put all of my weight on the corner being measured.
Based on that we should flip your 10K and 470 ohm resistors to make the passenger airbag active. To make it inactive, we are probably looking at increasing the 470 ohm to about 2.5K to 3K. When you have a chance, measure the voltage of one of your connectors from pin 2 to pin 3 for me. Also measure Pin 1 to Pin 3. |
#92 | |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
#93 |
Oops... I meant I should change it to 470 from 1-2 and 10k from 2-3, right? I currently have it set with 10k from 1-2 and 470 from 2-3
#94 |
Correct 10K 2-3 and 470 1-2 for airbag always active.
#95 |
#96 |
#97 |
Fingers crossed!
#98 |
How's this look?
![]() I couldn't wait until tomorrow or Sunday
#99 |
#100 |
#101 |
#102 |
Did you by any chance measure the voltage between 2 and 3 and 1 and 3?
#103 |
#104 |
this is a really good read. Guys when it's all done, can it be compressed and posted as a DIY? I know a lot of people who would like to know how to do this!
#105 |
![]() ![]() ![]() Drives: 08 liftback 5spd Join Date: Oct 2008
you guys are no joke. if co-workers and married couples could co-operate as well in the same room as you guys are over a forum the world would be a very different place... rock on.
#106 |
We'll definitely turn this into a DIY once we figure it all out.
As far as clearing the current stored codes, Let's try a couple minute battery disconnect. The SRS system supposedly clears most types of stored codes if it is off for a while. If that doesn't work, we can manually clear them via that same jumper we used to make it flash the light patterns. The process for clearing them that way is a bit convoluted, so hopefully the power down will do the trick. |
#107 | |
#108 |
You could try it as-is to see if we clear the code 32 and have the passenger air bag on light.
| Possible Group Buy.. Racing Seats, Intakes? | TinyGiant | Items for Sale by private party | 60 | 09-11-2009 03:40 PM |
| FS: Recaro Pole Position Racing Seats (black) -- socal | 03Z33 | Items for Sale by private party | 13 | 12-07-2008 06:08 PM |
| sparco seats and pedals (pics) | turboyaris | Cosmetic Modifications (Exterior/Interior) | 18 | 09-05-2007 03:43 AM |
| Sport / Racing seats worth the while? | mikeukrainetz | Cosmetic Modifications (Exterior/Interior) | 10 | 11-19-2006 02:17 PM |
| Yaris Liftback Seats | artyin | General Yaris / Vitz Discussion | 3 | 04-30-2006 05:07 PM |
