Old 08-10-2009, 11:47 AM   #5
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Originally Posted by Morgan View Post
no should just be loosen that bolt (pointed to with red arrow in pic above) and get something like a crow bar/handle to the floor jack and leverage it against the engine and push the alternator out/towards the bumper to increase tension OR you can hit the top of the alternator with a hammer til its in the right place... sometimes these things A LOT of force, can't really hurt it by whacking it
Sorry, this is terrible advice. You most certainly CAN hurt an alternator by hammering it. Someone elsewhere said a replacement alternator cost them $700+!
As pointed out elsewhere, you have to loosen the base bolt(s) as well as the adjusting bolt on top - the alternator can easily be moved by hand then. Tighten to specs, then tighten the top bolt, then the base bolt(s).
Sir A.Y. Atoyot is offline   Reply With Quote
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
revamping the DIY section supmet Suggestions - Feedback - Questions 7 03-23-2009 02:01 AM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
