Old 08-03-2010, 06:18 PM   #1
Bluffnaked
Drives: 2007 Toyota Yaris
Thank you CT, I didn't even notice that one until you pointed it out lol.
And success, installed and working like a charm. Thx to CT for the indication box, and the PDF. Although I think the DIY PDF reads wrong about the location of A21.
"4. Run the positive wire (red wire on last page pictures) to pin 40 of ECM connector A21. This connector is the one on the right plugged into the ECM (left side of the engine bay if you are standing in front of the car). You must first cut the ziptie, push the clips (I used a small screwdriver) and undo the hooks to remove the cover as shown by nickhjort in the following picture. Then you push the little rubber that is in the pin40 out with a pin and get your wire through. I suggest that you skin the wire on 1-2 cm, twist it and then cut it as close as possible to the connector after you pulled
it from the other side."
On my car A21 is the right side of the ecm when I'm standing in front of the car, it's the smaller one of the two. When you read the above paragraph from the DYI PDF, it starts to say right side, then goes to say "left side of engine bay if you are standing in front of the car". This threw me off, so I wrestled with the other connection which is a lot harder to get off for a while, till I realized I had the wrong one. LOL anyway just wanted to point that out. And of course I do appreciate the DYI, because I was close to having the dealer install it for me for the tune of $500 big ones.
http://www.thecnz.com
Bluffnaked is offline   Reply With Quote
Old 08-07-2010, 11:48 PM   #2
drunix
Drives: 2010 Yaris 3D LB
I just finished a 1000 mile trip with the 2 button cruise control and I liked it so much that I upgraded to a variation on the 4 button version. While on the road I picked up a MOMENTARY-OFF-MOMENTARY toggle switch (at HSC Electronics in California, $1.49). I now have Up=RES/+ and Down=SET/- on the switch, a low profile Microswitch push button for On/Off and a C&K white pushbutton for Cancel.
By using 3 differently shaped controls, I can feel the difference, so I don't need to be able to see them. I had the push buttons in my stash.
The toggle switch is similar to this: http://search.digikey.com/scripts/Dk...name=EG2388-ND
Note also this is a 2010 Yaris automatic, stripped down (no power package), and it had the cruise control wiring in place.
drunix is offline   Reply With Quote
Old 08-08-2010, 02:29 PM   #3
sheraz2000
sheraz2000's Avatar
Drives: Vitz 2006
Send a message via MSN to sheraz2000
i have one question here.
My yaris D3 connector has one cable (black). When i remove this connector, the horn stops working. is it the horn connector ? what kind of power does this cable provide. Negative or positive ? also the pin 40 on the ECM doesnt contain any sort of power when i check it with a power meter. Is it supposed to have any pulse or something? i am just a little worried to not damage the ECM by doing this sort of a setup. Is it safe ?? 100% ?? :p
---- its fun to be in a vitz!
sheraz2000 is offline   Reply With Quote
Old 08-08-2010, 04:23 PM   #4
CB900F2
Drives: 08 Sedan
Scott... It appears for my 08 CND Sedan, the wire run from the ECU to AD4 is there, and what is missing is the wire run from AD4 to D3..
Since AD4 is tucked way in the top left side of the inner dash, not sure if you have ever taken apart your Yaris's top dash, and if you have noticed if both ends of AD4 have the light blue wire.. I am really hoping Toyota has the wire run from AD4 to D3, but only decided to tuck away the run from AD4 to D3 some where.
I would find it odd that all of the other wiring is there as even the clutch switch is there, but they manufactured the wire harness with only missing the run from AD4 to D3
What do you think?
CB900F2 is offline   Reply With Quote
Old 08-08-2010, 10:02 PM   #5
What do you think?
Getting to AD4 requires removing the top of the dash. The wire from AD4 to D3 is definitely not tucked, as it would be part of the harness that also contains the horn wire.
Old 08-08-2010, 10:00 PM   #6
I don't believe that Yaris for your area have the cruise functionality. Besides that, the black wire is the horn. There are two additional wires that get added to D3 for cruise control.
Check out this thread for more info:
http://www.yarisworld.com/forums/sho...ght=faq+cruise
Old 08-09-2010, 12:40 AM   #7
sheraz2000
sheraz2000's Avatar
Drives: Vitz 2006
In my area YARIS is not available, so i had to buy it from JAPAN. Does it work with JAPANESE models ??
Old 08-09-2010, 12:43 AM   #8
sheraz2000
sheraz2000's Avatar
Drives: Vitz 2006
also i have got a Yaris sedan (BELTA in japan) . got 3 wires in D3 connector. Got it also from JAPAN. can i do the CC with both these cars ??
Old 08-09-2010, 08:51 AM   #9
If the Belta has blue and brown as the other two wires in D3, then it should work. If it has the cruise control indicator in the cluster, then to test it just jump the blue to the brown with the ignition on and the CC indicator should light.
For the other, which just has the black wire, the best quick test is to measure the voltage on the ECM pin (A21-Pin 40) with the ignition on. If CC is active on the ECM, then that pin will have 12V on it.
Old 09-08-2010, 12:38 PM   #10
sheraz2000
sheraz2000's Avatar
Drives: Vitz 2006
well, when i opened up the D3 connector on my belta, i got these wires. Tell me what to do from here forward. SORRY about the blurry pic, was taken from my mobile cam. But the wire colors r pink, orange, grey and black. there is no blue and brown cable. How to check if my car has CC in ECM.
Old 09-08-2010, 02:29 PM   #11
Those three wires are for the steering wheel audio controls. If a Yaris is wired for them, then it definitely does not have Cruise Control. Based on the wiring diagrams, areas that have steering wheel radio controls do not have cruise control and areas that have cruise control do not have steering wheel radio controls.
Old 09-09-2010, 12:04 AM   #12
sheraz2000
sheraz2000's Avatar
Drives: Vitz 2006
but, my steering wheel doesnt have any radio controls. can i do the CC still, using the pin 40 method and using the black wire ?? (while ignoring the rest of the cables) ???
Old 08-12-2010, 04:32 PM   #13
Daren
Drives: 08 Black Liftback S
Hello!
I have a question, I hope you all don't mind....
I have an 08 liftback, MT, without wiring. I've installed the buttons and the wiring to ground and ECM. I don't have a harness for the clutch switch, so I need to rig the switch to go into the fuse box in the engine bay. (If this is wrong please correct me)
The clutch switch has two contacts, so I assume I run two wires off of those contacts into the fuse box. My question is which wire goes where? Looking at the picture on the top of the 4th page of the pdf, I'm not entirely sure.
Daren is offline   Reply With Quote
Old 08-12-2010, 09:18 PM   #14
Originally Posted by Daren View Post
Hello!
Correct on the clutch switch wiring. The clutch switch goes to the blue wire indicated below and the white wire, to pins to the right of the blue.
Old 08-12-2010, 10:10 PM   #15
Daren
Thanks for the response! Checking to make sure I understand:
So both wires from the clutch switch splice into the blue wire and the white wire is moved to the right of the blue?
Last edited by Daren; 08-12-2010 at 10:13 PM. Reason: The internet has made me dumb.
Old 08-12-2010, 10:28 PM   #16
No, one wire from the clutch switch connects to the blue and the other connects to the white.
Old 08-13-2010, 03:01 AM   #17
Daren
Thank you so much.
Old 08-12-2010, 06:11 PM   #18
r0chin
Drives: Sedan 2009 Automatic
Would this work on a 2009 Sedan?
r0chin is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
