View Poll Results: Would you buy one?
No 5 5.10%
Yes (for $75) 46 46.94%
Yes (but it would have to be less than $75) 7 7.14%
Yes (but I still want it to also display the time) 40 40.82%
Voters: 98. You may not vote on this poll
Old 01-10-2010, 10:22 PM   #1
Originally Posted by arunto View Post
unit looks nice....i can't wait till it comes out. would we use the current push button on the cluster to change between functions?
Yes. It will use the same push button to change modes and set the clock. Programming for the one button user interface has been one of the most difficult aspects of this, but I wanted to avoid making people drill holes for extra switches.
Old 01-10-2010, 10:12 PM   #2
joshpjost
Drives: Yaris 2008 Sedan
I am interested in how you'd incorporate it into the sedan! I'll buy.
joshpjost is offline   Reply With Quote
Old 01-11-2010, 10:04 PM   #3
cdydjded
Drives: Yaris LB Turbo
Yes I agree with you, if you can add it I think it would be a good option. Also you mentioned you could remove the speed limiter, again some people might be interested in that also.
cdydjded is offline   Reply With Quote
Old 01-12-2010, 11:18 AM   #4
kaly5
Drives: 07 blazing blue hatch
Hi all,
New to the forum here.
CTScott - this one cool project you are undertaking. It is great enough to make me join the forum! Count me in for one of these. Thanks for your great work.
kaly5 is offline   Reply With Quote
Old 01-13-2010, 08:49 PM   #5
Revsson
Looking good CTScott!
With these tap splices, will it be easy to put back the old unit, in case I
would sell the car?
Old 01-13-2010, 10:04 PM   #6
would sell the car?
Yes. You'd pop them off and put a small piece of tape over the nick in the insulation.
Old 01-14-2010, 01:50 AM   #7
RedRide
RedRide's Avatar
would sell the car?
Why remove it if you sell it?
I suspect that any new owner would like the mod also.
Old 01-14-2010, 01:55 AM   #8
IsLNdbOi
IsLNdbOi's Avatar
... and it probably wouldn't work on other cars unless you plan on getting another Yaris if you sold your current one.
Old 01-14-2010, 11:42 AM   #9
DenverDave
Drives: 2010 Hatchback
After reading this thread it appears the YarGauge will not work on my 2010 3-dr manual, which has a tach on the left.
DenverDave is offline   Reply With Quote
Old 01-14-2010, 11:54 AM   #10
That's correct, since the clock is not a separate module, like on the tachless ones. I am trying to figure out where the YarGauge could be integrated to have the OEM look for tach equipped liftbacks and sedans.
Old 01-14-2010, 02:26 PM   #11
goku87
goku87's Avatar
Drives: Black HB
Oh that sucks. I was totally going to buy one but didn't know the new ones came with a tach lol.
goku87 is offline   Reply With Quote
Old 01-14-2010, 02:48 PM   #12
For 2010 all manual transmission LBs come with the tach. Autos still do not.
Old 01-14-2010, 11:34 PM   #13
goku87
goku87's Avatar
Drives: Black HB
About time, but I wanted all the other cool functions too lol. Can't have everything I guess? lol
Old 01-14-2010, 04:41 PM   #14
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Still want me to take some pics of the inside of my cluster? I have one with a tach - just tell me what you need a pic of and I can do it tonight.
devinlamothe is offline   Reply With Quote
Old 01-14-2010, 04:52 PM   #15
I actually have one on my test bench. I don't see being able to mount it within the tach cluster without modification, so I am looking for someplace outside of the cluster. For example, one thought is to mount it in place of one of the center AC vents. I am open to suggestions.
I obviously could mount it in a small enclosure, that you can put anywhere (like the scangauge), but that diminishes its value versus products like scangauge.
Old 01-14-2010, 07:05 PM   #16
devinlamothe
Alright then. I am going to look tonight to see where would be a good place to mount it (for me anyway).
One question though: since we can't replace the clock module, is hooking it up going to be more difficult? IE: are more spliced required?
Old 01-14-2010, 07:52 PM   #17
You'd have 3-4 more wires to tap:
Ground, constant power, switched power, and possibly dimmer.
To install the proto on my 09 w/out tach, I only had to tap one wire (outside temp sensor), as I realized that the two can bus connections could be made to two test points on the back of the cluster.
Old 01-15-2010, 01:11 AM   #18
advocate
Drives: car
Scott, your product is 50x cooler than the scanguage and developed IN HOUSE SPECIFICALLY for people who own Yarii. That makes it more enjoyable and rewarding to own and use.
For example when people get in my car I proudly tell them that some crazy CT electrical engineer fabricated up a switch for my airbags.
This is a great project and you shouldn't fear the scangauge because yours is going to be way better!
Also, as an owner of a tach, I would like to see a version of it fit under my single DIMM head unit or as an AC vent replacement, both are great ideas.
in dash clock as tach? Cosmonaut In Car Entertainment + Electronics (audio / video / alarm) 10 07-12-2010 11:27 AM
digital tach, 52mm, preferably blue leds severous01 Cosmetic Modifications (Exterior/Interior) 5 05-15-2009 10:58 AM
Digital Tach nqd Performance Modifications 4 05-17-2007 12:04 PM
