View Poll Results: Would you buy one?
No 5 5.10%
Yes (for $75) 46 46.94%
Yes (but it would have to be less than $75) 7 7.14%
Yes (but I still want it to also display the time) 40 40.82%
Voters: 98. You may not vote on this poll
Old 09-03-2009, 10:59 AM   #37
Speedjunkiejp
Drives: 07 Yaris Sedan
i dont get it, i run my vin and it comes back a non-s but i have integrated radio and a tach. guess I am out of this :-(
Speedjunkiejp is offline   Reply With Quote
Old 09-03-2009, 11:41 AM   #38
If there's enough interest for non-left hand clock people, I'll just offer a "packaged" option, where the device is in a plastic box like a ScanGauge.
Old 09-03-2009, 01:45 PM   #39
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I have a 2009 sedan and my clock is on the right.
Old 09-04-2009, 02:25 PM   #40
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Interesting. So, all Canadian Yaris have tachs, or just have the clock as part of the fuel gauge?
We all have tachs + the clock is part of the fuel guage setup.
devinlamothe is offline   Reply With Quote
Old 09-04-2009, 06:24 PM   #41
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
I think all the Yaris over here have Tach's as well , at least in the Hatch back they do
Cause we have the Digital dash
i am more interested in water temp , and fuel mileage .
just so you know
And THANK YOU VERY MUCH , for even looking to do this .
Old 09-04-2009, 06:47 PM   #42
bladesmith6
Drives: 2007 yaris HB
No you're pretty much correct only the US manual trans liftbacks got completely fucked. toyota usa engineering idiots...
bladesmith6 is offline   Reply With Quote
Old 09-04-2009, 07:33 PM   #43
yarstar
Drives: 2008 Absolute Red HB
I COMPLETELY AGREE.
CT: I am so down with this! You wlll solve the 'no tach' issue very OEM and I can finally get rid of my aftermarket tach.
I love the idea of an outside temp option.
I agree with Garm. This a a great idea and I will buy it a heartbeat.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 09-04-2009, 10:08 PM   #44
IsLNdbOi
IsLNdbOi's Avatar
If this turns into a an external device (like smaller version of the ScanGauge) and turns out it's not going to be a replacement for the digital clock, then count me out.
Also, to get outside temps. you'll need to sell a thermometer probe like the kinds used with Gentex and CIPA rear-view mirrors that show outside temps., right?
Old 09-04-2009, 10:58 PM   #45
For the right hand clock clusters, there's no place within the cluster to mount it (without cutting plastic). My original thought with this whole thing is that it would really be for the tachless people. It started off as simply a tach in place of the clock and then the more I thought about it the more features that kept popping to mind.
Correct on the sensor probe for outside temp (although if I can figure out the CAN messaging for the A/C ECU, I can use it's outside temp probe and save people having to run a probe wire through the firewall).
I am making great progress on this. I built a CAN bus interface this week and can read the PIDs (all of the standard OBD data), can read and reset stored DTCs, and can sniff the communication on the CAN bus between the ECM and the body ECUs.
Old 09-04-2009, 11:01 PM   #46
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Progress, is good , you so need a Yaris Medal of Honor
Old 09-04-2009, 11:03 PM   #47
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
i want one and i don't even have a clock
Originally Posted by xnamerxx
you nailed it sir.
Old 09-04-2009, 11:29 PM   #48
IsLNdbOi
IsLNdbOi's Avatar
So are you planning on two versions? One being a replacement for the clock module for the ones with the left hand clock and one for those with the right hand clock?
The whole allure in this in the beginning was in replacing the clock with a multi-function device that fit in the same spot.
Old 09-05-2009, 12:32 AM   #49
The right hand clocks can't really be replaced, since that display is non-removable and integrated into that display is quite a bit more than just the clock. You just have to figure out another place on the dash where it can be installed to still look OEM. Maybe there's something else that we can pop and replace on cars like yours.
Old 09-05-2009, 02:05 AM   #50
IsLNdbOi
IsLNdbOi's Avatar
Oh no, I was just wondering. My clock is on the left like all other 5-door '09s in the US.
Old 09-05-2009, 02:43 AM   #51
l2a3k2a3i
Drives: 2008 Red Yaris LB 5 sp
Count me in. Ill buy one in a heartbeat!!1
l2a3k2a3i is offline   Reply With Quote
Old 09-05-2009, 12:11 PM   #52
Revsson
I like the idea of a temperature readout and a clock, and the other features.
Being that my car is still brand spanking new to me (10 months), I still haven't taken
anything apart on it. However, I might be forced to try a mod.
Old 09-05-2009, 01:12 PM   #53
enviri
enviri's Avatar
Drives: 2010 Yaris
oh, oh, how about intergrating a scangauge in the cluster? im sure the LCD is detachable from the rest of the circuit board! get anotehr lcd size and stick that sucker somewhere :P
Old 09-05-2009, 10:54 PM   #54
yarstar
I don't even know what any of that means, but you sure sound like you do! I am so excited about having a digital tach in my OEM cluster! Keep up the good work!
in dash clock as tach? Cosmonaut In Car Entertainment + Electronics (audio / video / alarm) 10 07-12-2010 12:27 PM
digital tach, 52mm, preferably blue leds severous01 Cosmetic Modifications (Exterior/Interior) 5 05-15-2009 11:58 AM
Digital Tach nqd Performance Modifications 4 05-17-2007 01:04 PM
