Old 09-05-2009, 11:12 AM   #1
BailOut
Steals terrorist's lunch
BailOut's Avatar
Originally Posted by ka0sx View Post
The only thing is that you are probably reducing maybe 1/2 mpg running the AC in a car like this so there shouldn't be an argument over something like this. I don't care how much of a tree loving into the green hype hippie someone is. 1/2 mpg is not going to change anything.
Actually, running the a/c is a 6-11% hit on MPG any time the compressor is cycling, which is much more often than not. That makes it exponentially less efficient than your initial thinking, and puts it well into the realm of measurably using more energy under "normal" operation, and measurably wasting energy if one has the windows down at the same time.
- Brian
Share the Road
Old 09-05-2009, 01:31 PM   #2
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
But the question boils down to whether or not windows down affects how often the compressor is running.
If I run the A/C on fresh, the drop in temperature across the evaporator is purely based on the input of outside air.
If I run the A/C on recirc, I can see how windows down would not allow air conditioned air from being the cooler input to the evaporators.
Old 09-05-2009, 08:04 PM   #3
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I believe you've got it right.
Old 09-06-2009, 03:55 AM   #4
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Long you have a hard head. If you drive with the windows up and it doesn't matter fresh or recirculate, the temperature in the car would get lower and you would reduce the fan speed which would reduce the load on the compressor which would reduce fuel consumption. Your GF is correct.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
