Old 09-10-2009, 10:17 AM   #1
Lafiro
Drives: 06 Yaris Sedan
I noticed that my rotors seem fine too, no lip or anything, at all, and it just amazes me.
But on a side note, I noticed the car does a lot of very heavy engine breaking. I do not understand why. Like I let go of the gas, and it really starts to slow down, even though its not revving high at all. I tested this on my dads new car, and it will go on almost forever stating +60MPG and barely slowly down.
So what gives here with my Yaris? : (
Old 09-10-2009, 06:52 PM   #2
1stToyota
1stToyota's Avatar
Help my brain out...you're the one that adjusted your rear brakes awhile back and had only 1-2 clicks at the hand brake...?
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 09-11-2009, 04:25 AM   #3
WolfWings
WolfWings's Avatar
Drives: Silver 2007 3Dr - Gryph
Very few cars have complete fuel cut-off. That's something I got used to having back with that DSM Eclipse I mentioned, it was one of the first consumer-grade sports cars I'm aware of that would shut off the fuel injectors entirely as long as your revs were a couple hundred above idle, so the engine could provide a relatively decent engine-braking effect.
Same thing with the Yaris: It has a LOT more engine braking power than a 1.5l mid-80's Civic, for example, because the mid-80's Civic never stops sputtering fuel in and exploding it, giving little nudges. Yaris? Same effect as turning off the engine whenever you're coasting with your foot off the gas pedal entirely.
WolfWings is offline   Reply With Quote
Old 09-11-2009, 08:54 AM   #4
seth_man
seth_man's Avatar
Drives: 08 Liftback
ive got 43k Miles on my stock brakes. 7 track days and never any brake issues. i have adjusted and cleaned the rears twice but still lots of friction material left front and rear and my rotors are now blue but still roll straight. at 40k i cleaned the brakes and measured the lining thickness, i still have 9.2mm of 12mm on the front pads and 2.9mm of 4mm on the rear shoes.
seth_man is offline   Reply With Quote
Old 09-11-2009, 10:39 AM   #5
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
hitting 56000 miles not ready for pads yet i think its due to fwy miles but its cool would have thaught i needed new pads by now im sure it right around the corner
pennyracer is offline   Reply With Quote
Old 09-11-2009, 11:50 AM   #6
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
34k... I do a lot of engine braking so i'd be surprised if I need new pads before 70,000 miles. Hopefully I can make it to 100,000.
Old 09-11-2009, 12:10 PM   #7
Lafiro
If most of us, like me, are reporting almost like new brake pads, and rotors that don't have any lip and look/perform just fine, I won't be suprised if most of us make it to 120,000Miles being needing to change them out.
As for the rear drums and shoes, the shoes would most likely have to go before 70k. I think I noticed mine had cracks last time I checked, so I will look at them one more them in a week or two before it gets colder.
Old 08-12-2011, 06:11 PM   #8
"G"
Drives: 2007 Yaris Hatch
100K and mine need to be replaced.
"G" is offline   Reply With Quote
Old 03-17-2012, 08:26 AM   #9
Em_
Drives: 2007 Yaris
i just replaced mine at 100 000KM but car sat for 5 months and the rotors were soooo rusted the pads were braking on 10% of the surface the calliper pins were sticking
i put 6$ worth of grease in them so it should be fine
Em_ is offline   Reply With Quote
Old 03-17-2012, 02:38 PM   #10
detroiter
detroiter's Avatar
I'm at 131,000 and have original pads/rotors.
Old 03-20-2012, 07:15 PM   #11
walt101786
Drives: 07 Toyota Yaris Hatch-Back
I got like 70k on my HB and still got like 45-49% left on the front and the rear....i resurfaced the front rotor once and clean and readjust the rear...so far its good for me...
walt101786 is offline   Reply With Quote
Old 04-01-2012, 01:01 AM   #12
GeneralDon7
Drives: Yaris Sedan
Just passed 110,000 with original pads and rotors and still have a quite bit left (more than my wifes 2007 prius )
GeneralDon7 is offline   Reply With Quote
Old 08-19-2012, 01:47 PM   #13
En4sir
En4sir's Avatar
Drives: '09 Yaris 3dr HB 5sp
I have 115,000 miles on my 2009 HB and still have all the original brake components. I plan on doing a brake job in the near future though.
"Never argue with an idiot. They drag you down to their level, then beat you with experience."
En4sir is offline   Reply With Quote
Old 08-19-2012, 03:58 PM   #14
dinoman
Drives: '07 Yaris LB
i think the brake wear really depends on how you drive. obviously if you are in NYC and doing stop and go all the time, you will wear the brake/rotor much faster than someone like me who only drive on a highway. Pretty much no braking for me and I was on my original pad for like 100K. I only replaced mine was because firestone in my neighborhood had a $99 break job with a set of Wagner thermoquiet ceramic pads. Considering that a shop charged me $40 to cut the rotors on another car, I thought it was a decent price for not doing it myself.
dinoman is offline   Reply With Quote
Old 08-19-2012, 06:12 PM   #15
nookandcrannycar
I have a bit over 223k miles at the moment on my car and I had the brakes checked at 207,165 miles and at that point, each corner-----LF, RF, LR, RR, = worn 20%/80% remaining.
Old 08-20-2012, 01:51 AM   #16
nookandcrannycar
I forgot to include they are original, no replacement yet
Old 08-20-2012, 08:08 AM   #17
"G"
Of course. Their is always someone like this on every internet forum.
Old 08-20-2012, 05:39 PM   #18
nookandcrannycar
....written by someone (you) who doesn't know the difference between their and there.
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
Which front bar do you prefer? Strut or Sway? TitaniumBarbell Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-16-2009 11:52 AM
Front spoiler koolerking Australia 3 07-20-2009 08:10 PM
Front bra for S model Sedan? N9QGS DIY / Maintenance / Service 2 06-27-2009 08:51 PM
