#109 | |
noticed the correction factor ratio (tfc) is at 1.00, does it mean there isn't any correction applied to the figures? (or if there is any needed???)
454 whp, 1.7 bar boost, pump gas, water/meth. 501 whp, 2.2 bar boost, pump gas + avgas, no water/meth. www.viosturbo.com - World's first 500 WHP 1NZ-FE Last edited by changchewsoon; 09-04-2009 at 09:07 AM. |
#110 |
I don't know that, it was a chassis dyno if that means anything. I can certainly ask.
#111 |
total correction factor (tcf) inter your drivetrane loss % to find out actual hp
05 Scion tC allmotor 350+ hp 9.34@144mph 05 Scion tC sfwd 880hp 9.96@147mph 05 Scion xB 280hp 12.97@104mph 07 Toyota Yaris 357hp 12.80@107mph Last edited by scioncrew; 09-04-2009 at 10:07 PM. |
#112 |
AD&D Dork
Drives: 07Liftback/07sedanS Join Date: Oct 2008
at 300hp thats something like what, 1hp per 7lbs... sick
![]() Mods: K&N filter, Megan Coilovers, Ultra Racing 19mm rear sway bar, Sun tachometer, Window Tint. |
#113 |
Who said Yaris was slow?
So when are we having some 1/4 mile times and track videos???
#114 |
Audio Junky
no joke... i'm watching this thread just to see 1/4mi time and speed.
#115 |
300hp would be about 280-285hp on a dynojet. With that kind of power, the Yaris should ET in the low 12's (assuming any semblance of traction) and trap about 115mph.
You still on stock transmission? How do those long ass gears feel in boost? Also, I missed the EMS you're using...I think you converted your wiring harness over to a TC or something like that to use their AEM?
#116 |
Wow, I am amazed at the work. Way to go Garm, keep up the great work. Good stuff to rear. Can't wait to hear from you with more updates!
#117 |
I think a DynoJet (rollers) would show higher hp, not lower. That is my experience with them, anyway.
Still on stock trans, and I am liking the gears with this much power. We ripped out all factory wiring, and re-wired by hand for the AEM EMS.
#118 |
Drives: 2009 TOYOTA YARIS SEDAN Join Date: Aug 2009
You can tweak a Dynojet to read anything you want within reason. Gimme an Eddy Current dyno FTW.
#119 | |
What kind of boost control you running? If you plan on taking it to the track, hope you got the boost by gear setup in the AEM with a MAC/AEM solenoid!
#120 |
AEM tru-boost controller/gauge. A/B settings for 13 psi/20psi. AEM solenoid.
it's just ok, I'm not thrilled with it just yet, but it does hold boost where it's supposed to be, and I did get a pretty nice power curve.
#121 |
videos....
#122 |
Just call me Ray, better?
+1
| NST Sponsored Dyno Day In Houston | NonStopTuning | NonStopTuning | 24 | 10-05-2009 02:26 PM |
| dyno day | psychopinay42 | California | 1 | 08-03-2009 03:42 AM |
| looking for a cheap dyno day in central tx | andruboz | Southwest | 6 | 05-08-2009 05:27 PM |
| Black Friday | Bob_VT | Off-topic / Other Cars / Everything else Discussions | 70 | 11-29-2008 07:07 AM |
| Dyno Day 09/29 10-2pm SoCal | DuckinOut | California | 20 | 09-29-2007 03:47 PM |
