| View Poll Results: Would you buy one? | |||
| No |
5 | 5.10% |
| Yes (for $75) |
46 | 46.94% |
| Yes (but it would have to be less than $75) |
7 | 7.14% |
| Yes (but I still want it to also display the time) |
40 | 40.82% |
| Voters: 98. You may not vote on this poll | |||
#55 |
I was looking at the clock today and I think it'd be better to just leave it as a single line instead of a double line. I think the characters would just be too small. Have you committed to a double line display?
#56 |
I have a few different one line and two line LCDs on order to experiment with. The clock digits actually only fill about half of the height of the opening, so it may be possible to use a 2 line display with characters nearly the same size as the clock's.
#57 | |
![]() Drives: 2009 5D Yaris Join Date: Feb 2009
#58 | |
I'm using two PICs within the design. One dedicated to the CAN Bus communication and the other for the user interface, direct RPM sampling and temp input. The ELM PIC is way too expensive at $23 each. I built a code reader for ISO-9141 (K and L line comm) about ten years ago. The messaging for the CAN bus is very similar to OBDII, so most of my work thus far was redoing my hardware interface for CAN. |
#59 | |
well it's expected, it's really more of a hobby thing and i'm no CS major. But i have one way I can help out.. I've got a few ideas for making a attachable design; hopefully a design that would cost >5bucks worth of laser cut parts and possibly less in bulk. If you want to go with larger 2x24 or 2x16 LCDs instead i think it would be easy to make a housing and attachment clips for it. it may be a little more costly through this route but i think it would make a world of difference |
#60 |
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
A design that I just thought of at the moment would be to have a progressive RPM bar that starts on one side of the display and move its way over. So instead of a digital numerical readout it would be a digital bar that would "fill" as the rpms went up.
If you could do that, and integrate the clock into the same display, I think you would deserve a medal haha. I had an idea that the clock would sit on the edge of one side, and the tach on the other. The tach would fill across the display and would overlap ontop of the clock if the RPMs got really really high. (If you're redlining, you're not worried about what time it is) I MS painted this picture in about 2 minutes flat but I think it gets my idea across. Don't laugh too hard at my terrible drawing skills ![]() I blame my laptops touchpad Last edited by advocate; 03-17-2017 at 05:03 PM. |
#61 |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
After thinking about it, I would probably still buy this and find a way to rig it into my cluster. If I had to disable the clock on the right side I would do it.
It's too awesome to pass up. :P |
#62 |
At some point when you have nothing better to do, pop your cluster out, take the covers off and take a bunch of pictures. Maybe we can figure out a good place to integrate it where there's dead space and no circuit board.
#63 |
★weeaboo★
I think the left side in between the odo trip reset button and the tach would be a good option, but you'd have to cut a hole for the display in the plastic obviously.
I have to take mine out next week when I take my car in for warranty service so I'll take pictures if I have time. |
#64 | |
![]() But yes, it will most likely involve me dremelling a hole or something out of the plastic shroud in the cluster. |
#65 |
So, I had Crashy's ECM fired up on my bench today as I was getting tired of having to go from my office to the garage to do some testing. I built a couple of circuits to make sensor data inputs to the ECM change, so I could vary the data (Speed, RPM, and Coolant Temp).
After successfully fooling the ECM with the 3 circuits, I realized that the speed one could be a fairly simple way of bypassing the speed limiter. Does anyone who races (legally) have an interest in testing that functionality? |
#66 | |
#67 |
#68 |
no, but Ill test it anyway, lol
#69 |
#70 |
Bypassing the speed limiter seems like an amazing idea to me... would certainly increase the value of the module as well...
You might have to just call the whole thing the "one mod wonder fix" for all Yarii without tachs
#71 |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Toyota Yaris Liftback Join Date: Oct 2008
I'm definitely 100% for this idea and will buy one in a heartbeat! Keep up the great work CTScott!!
#72 |
I wouldn't build the speed limiter bypass into this module. It would be a separate stand alone module. The technology for it just happened to be an accidental benefit of me working on the YarGauge development.
| in dash clock as tach? | Cosmonaut | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 07-12-2010 11:27 AM |
| digital tach, 52mm, preferably blue leds | severous01 | Cosmetic Modifications (Exterior/Interior) | 5 | 05-15-2009 10:58 AM |
| Digital Tach | nqd | Performance Modifications | 4 | 05-17-2007 12:04 PM |
