![]() Drives: Yaris S sedan Join Date: Sep 2009
HID kits?
so ive had my yaris for sometime now and i really want hid's but im very cautious to buying a kit and it not work on my car. who has installed them and where did u get your kit from
Eugenie たでし
Drives: '09 Blazing Blue Liftback Join Date: Aug 2009
Xentec 8k's
drop in HIDs are easy to put on, go with Bi-xenon they have better cutoff, however that is only in comparison with single beam HID, for true HID affect of dramatic cutoff you will need to do a retrofit. Caliyaris on this forum sells both. There are FYIs on the install.
http://shop.microimageonline.com/cat...?categoryId=16
There you go. I've seen the actual kit in person, and it is nice. Works very well, unlike my eBay kit. The projector kit is very nice if you have some extra cash. It gets rid of the glare that a drop in HID kit produces in a halogen housing. |
thanks everybody. on those projector kit do i have to cut to fit that in the headlight housing or does it drop in
You'll need to use a dremel to make the hole slightly bigger, but nothing too hard. There are two DIY guides here that you can use to install them.
#7 | |
![]() ![]() ![]() Drives: 2007 Yaris S Join Date: Jan 2009
he only used it when putting the amber panels back in all you gotta do is open the headlights up and follow each step precisely as stated in the DIY
Project LEGATO
![]() ![]() ![]() ![]() Drives: '07 Yaris turbo, '11 Juke Join Date: Mar 2007
The projectors are a perfect fit in the sedan headlights. The only cutting that is required is to notch
the turn signal housing so the bottom of the projector doesn't hit it.
http://www.cardomain.com/ride/3875996 |
Yah, brian and camell both didn't need a dremel for the projector to fit in the housing. Only I needed it for the liftback. Either way, it was a MINOR task, if even that.
Oh!!!! hahaha, I just remember seeing dremel in one of their threads. I thought they used it to make the hole bigger. My bad.
| HID kits - $115 shipped! | cali yaris | Sponsors Classifieds Area | 18 | 07-25-2012 09:16 PM |
| FS Onyx HID Kits | JM Auto Racing | Items for Sale by private party | 5 | 07-23-2009 12:08 AM |
| FS: Onyx HID KITS | JM Auto Racing | Items for Sale by private party | 29 | 06-04-2009 03:55 PM |
| HID Blowout F1Spec Kits! | 365Motorwerks | Sponsors Classifieds Area | 30 | 04-05-2007 12:38 AM |
