Originally Posted by arcticvitz
In that case would your recommendation be to leave in the spare tire as well since it adds weight to the rear and makes a better balance? Losing 30 pounds of weight below the center of gravity in the rear probably makes a pretty profound difference as well does it not? If better handling means making the back end heavier since there's nothing left to pull out from the front then why not even put a sub woofer box back there on top of the spare tire and make it nice and heavy? Sure acceleration suffers but essentially that would give you a better weight balance correct?
what i'm saying was, that's an awful lot of work and risk for such a small amount of weight loss, especially when it's from the wrong end of the car. in this case a carbon fiber hood actually makes more sense
