#181 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
I will fix for sure the brake light... Within these months I was too busy looking at the engine bay instead :) Next mods DEI silicone spray on the exhaust mainfold/downpipe/turbo ceramic + DEI Titanium best wrapping out there. In need of upgraded front suspension + semi-slics tires... Just booked some drag races for next weekend :) |
#182 |
^ nice, can't wait to see your times! going to be QUICK!!
#183 |
your car looks and sounds great my friend!
now, may i suggest a set of water/methanol injection kit? :)
454 whp, 1.7 bar boost, pump gas, water/meth. 501 whp, 2.2 bar boost, pump gas + avgas, no water/meth. www.viosturbo.com - World's first 500 WHP 1NZ-FE |
#184 |
Thanks changchewsoon that will be an option for the coming future but still not in need since my intercooler hold intake temps below 25c @ 9psi.
First option will be upgrading to larger injectors maybe 632cc ones then upping the boost to finally another good tuneup session |
#185 |
is your current injector size insufficient? i bought FIC 445cc injectors but have not used them yet.
#186 | |
Update : Toyo Semi-slics 195x50 888 tires were installed on all 4 wheels. Gained more handling stability and traction :) |
#187 | |
Who said Yaris was slow?
#188 |
Well got my hands dirty again removing downpipe and several connections to prepare them for thermal wrapping etc... and I began wondering about the braking system.
During the last runs I noticed that the braking of the car takes too much to come to a stop also when not driving that fast. I am suspecting that the heat generated by the turbo exhaust chamber is causing the "compensator" situated just few cm behind to overheat o-rings inside. I am thinking of moving the hole part to the right (front view) but that makes some more work and more expenses... I also thought of coating it with silicone spray which is designed for extreme temperatures like turbos. What do you suggest me to do? |
#189 |
make a little insulated "heat box"
#190 |
#191 |
I'll try and take a pic from mine
#192 |
#193 |
Hard time to remove exhaust but finally coming to an end!
Turbo exhaust chamber, downpipe and exhaust manifold coated with DEI silicone high temp resistance paint. After paint dry wrapped turbo and downpipe with DEI titanium wrapping. Hopefully to get better engine bay temps. Next...... - Finishing some wiring organization - Red paint to engine cover and turbo/intercooler tubing - Adding sandwich adapter for oil temp and pressure |
#194 |
Parmas, here is the insulation box I made for the fuel system. Just a thought. You could do the same thing for your brake cylinder in the engine bay -- or anything else. This is pretty stiff aluminum with insulation on one side:
#195 |
Thanks for the idea garm will check on it surely...
#196 |
Some enhanced new looks.... All paint is designed to work above 500DegreesF.
Next completition of new coolant piping which will be come blue... Also done lots of shielding at the back panel area to protect brake lines from overheating. |
#197 |
Looks good man!!
#198 |
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
God this thread rocks.
| Motor Longevity | Pavel Olavich | DIY / Maintenance / Service | 10 | 03-17-2012 11:43 AM |
| cali yaris built motor | cali yaris | Performance Modifications | 83 | 09-03-2009 11:08 PM |
| Fan motor noise... | 500snakz | General Yaris / Vitz Discussion | 10 | 12-01-2008 02:43 AM |
| Exchanging Motor on a Liftback 1.3 Lt | weckjuan | Performance Modifications | 8 | 11-12-2006 10:58 AM |
