#73 | |
Drives: 07 Black Yaris LB, 05 Camry LE Join Date: Jul 2006
Opinions are not facts you seem to have that confused....
#74 |
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
Well it could be you had higher oil pressure because some passages were partly blocked restricting the oil flow. Using an engine flush and using synthetics will remove the deposits and may be causing the low oil pressure
OR maybe he used a lighter oil. OR there could have been a build up of crud in the sending unit. Synthetic don't tend to thicken over time like mineral oils do either so you may see slightly less pressure on the guage If it's a huge drop I would recommend testing the oil pressure. If it's a higher mileage engine use a slightly heavier synthetic oil say a 10W-40
The early bird gets the worm, but the second mouse gets the cheese. |
#75 | |
HardlyDangerous
#76 |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
what do ya'll think of 0w40 it is a very common weight oil for European cars
#77 |
HardlyDangerous
That would be perfect for an engine with high mileage
I run 0W-40 in my motorcyles
#78 |
Cousin Vitz
Drives: Yaris RS 5DR / Vitz RS wannabe Join Date: Mar 2006
This thread has bee a very good read.
07WYarisRS I am planning to change to synthetic in the spring. My current mileage is 10,000 km. From reading the previous posts, it seems like an oil flush is not necessary when changing from conventional to synthetic at lower mileages (ie. 8000 km a lower) I'm planning on changing to synthetic perhaps around 14-15K km, depending on the weather. Should I perform an oil flush at that estimated mileage, prior to using synthetic?
DIY Speaker Spacer/Bracket Template for Yaris Hatchback http://www.yarisworld.com/forums/showthread.php?t=1930 |
#79 | |
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
#80 |
Couple of questions... I'm planning to take a road trip around christmas, and I think I should get an oil change as well as a "just-in-case" checkup before I go.
So I'll be going synthetic after reading the wealth of information in this thread. Question #1: Redline, Amsoil or Royal Purple come is as highly recommended, but over here, as far as I know, are not available. Mobil 1 seems to be all right too, but what about Castrol? We can get GTX, Syntec, Magnatec, and so on, are they any good? Or else there's the usual Shell and other common brands. Question #2: It's the tropics here, temperatures only vary between about 25 and 40 degrees Celsius, and I see that most oils sold here are 0W30-0W50, does the ambient temperature make a difference or should I stick with a lighter oil like 0W20 as recommended here? Thanks!
#81 |
Here is a comparison of oils. http://www.1st-in-synthetics.com/10W30API.htm
#82 | |
HardlyDangerous
The rest like Mobil 1, Castrol Syntec, Motul, Qstate, pennzoil synthetics etc are all just highly refined crude/mineral based oil. IMO not worth the prices they charge A 0w-30 wont hurt in any temp however if you live in a tropical climate a 5w-30 is all you really need. Stick with the 30W oils, 20W oils are super light. While they can help mileage ever so slightly too light of an engine oil on a car under heavy load orextremem temps or high rpm operation can shorten the life of the engine.
#83 | |
Obsessive Detailer
#84 |
Roar?
im glad that i work at an autoparts store that sells amsoil . get it at cost :)
#85 |
You are one lucky dude! Do you use Amsoil PI? (Performance Improver)
#86 |
Roar?
i will use amsoil 5w30 not sure what the preformance improver is but they carry a bunch of ish from amsoil and i get it for less than $5 a quart :)
#87 |
I think i already posted... but MOBILE 1!!!!!!!! My yaris only deserves the best and when i went to Mobile 1 for my first oil change i told them nothing but the best they have. no other oil can compete with synthetic mobile 1 oil
#88 |
NCP91
Drives: 06 Vitz RS Join Date: Apr 2006
#89 |
Roar?
sorry bud bet mobil 1 is only more refined than regualr oil its not truly man made if you want real synthetic go amsoil
#90 |
That reminds me of a call I once got while working at Circuit City's Answer City. I was answering computer calls when this old man calls up and has a problem. Halfway through the call he said "I know quality and when I bought this computer I told the salesman, I want your best, so he sold me a Hewlett Packard Bell." The PC was a Packard-Bell Legend 2000. The biggest piece of crap ever to have a CPU. I pressed mute and started laughing until my sides hurt!
I guess that makes me an old geek!Here is the link to Amsoil PI. https://www.amsoil.com/storefront/api.aspx
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum Last edited by nsmitchell; 12-28-2006 at 09:05 AM. |
| LB M/T options | Howard2621 | New YARIS Purchase Forum | 1 | 09-22-2006 10:37 PM |
