#19 |
![]() ![]() ![]() Drives: 2007 MX5 Join Date: Feb 2009
This is exactly why CALI sucks to live in.
#20 |
![]() ![]() ![]() ![]() Drives: '07 Yaris turbo, '11 Juke Join Date: Mar 2007
When I got pulled over by CHP they looked under my hood and saw my TRD CAI. They asked where
the E.O. # for it was. Knowing it didn't have one, I just said I didn't know and that I got it installed when I bought the car. They didn't know any better. They also thought my HID ballasts had something to with altering the ignition and my scanguage 2 was a boost controller.
http://www.cardomain.com/ride/3875996 |
#21 | |
#22 |
![]() ![]() ![]() ![]() Drives: 2007 Yaris LB Join Date: Mar 2007
#23 |
![]() ![]() Drives: 07 sedan Join Date: Jun 2007
Emissions and fuel economy are the only reason why they design them the way they do. Noise reduction is an advantage. They do not give a crap about noise. Look at the rest of the car, there is really no sound deadening in our cars. Show me where you get your info from.
http://en.wikipedia.org/wiki/Warm_air_intake http://en.wikipedia.org/wiki/Califor...esources_Board http://en.wikipedia.org/wiki/United_..._Clean_Air_Act http://en.wikipedia.org/wiki/Internal_combustion_engine http://en.wikipedia.org/wiki/Atmospheric_pressure http://en.wikipedia.org/wiki/Manifold_vacuum http://en.wikipedia.org/wiki/Naturally-aspirated_engine |
#24 |
#25 |
#26 |
fmicle, I am not trying to knock on you but rather help you learn so don't take it the wrong way. I know sometimes the way I type things come out the wrong way. This is what is bad about the internet, there is no face to face communications.
#27 | |
Every time camelll posts this as fact:
Stop posting something as universal fact when it just ain't so in real life.
#28 |
Cali the law is fact, if you do not have a carb number on your intake you should not pass inspection. If the ref that is doing the testing passes your car without a number then they are breaking the law. You may get pulled over for speeding but not get a ticket, this does not mean you did not break the law.
The person that passed you was not doing their job. * edit * Are you saying that an aftermarket intake without a carb number is not against the law? |
#29 |
Also are you agreeing with fmicle about emissions and intakes?
#30 | |
This is common knowledge in California, that we can't import fuel from all over the country because not all refineries match the requirements for clean fuel (additives, sulfur, what not). |
#31 | |
#32 |
This is what octane ratings are all about, not additives. The price for everything is higher in California as compared to the Midwest. Our cars are made to run on 89 octane, you do not get better emissions with higher octane. I am not nit picking just providing reading material. I never said anywhere that fuel quality has to do with octane. Some gases my be formulated to reduce certain vehicle emissions depending on the state they are sold in but the main thing with octane is anti knock properties.
"The octane rating is a measure of the resistance of gasoline and other fuels to detonation (engine knocking) in spark-ignition internal combustion engines. High-performance engines typically have higher compression ratios and are therefore more prone to detonation, so they require higher octane fuel. A lower-performance engine will not generally perform better with high-octane fuel, since the compression ratio is fixed by the engine design." http://www.eia.doe.gov/bookshelf/bro...ine/index.html |
#33 |
#34 |
#35 |
what's legal and what you can get away with (or not get away with) are two very different things.
this thread is useless because obviously the law says a CARB sticker must be applied to any performance part for it to be legal. that's the law. end of thread, no more discussion.
#36 |
This has nothing to do with ego. I am curious if he feels the same way you do on air intakes. This is all substance. The law is factual and full of substance.
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| MY new PRM Intake... | marcus | Performance Modifications | 27 | 05-03-2009 11:04 PM |
| Bomz Ebay Intake - Partial Review | Split | Performance Modifications | 11 | 11-19-2008 02:12 AM |
