Old 10-09-2009, 05:11 AM   #22
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
A couple months back I got a TSB from Amsoil regarding silicon in various Toyota models and the Vibe. Enough that they recommend their EaO oil filters be changed at OEM intervals insread of the allowed 25000. If that oil pump was the cause in one csse stated earlier, the design might have commenalities.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
DIY Oil Pressure Gauge Install LtNoogie DIY / Maintenance / Service 13 11-20-2009 04:13 PM
Best tool I've found so far to remove oil filter PICS auxmike DIY / Maintenance / Service 22 11-28-2008 12:46 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
