![]() ![]() Drives: 2008 Yaris HB Join Date: Jan 2009
Ok if you go to the dealer and buy a Yaris in "A" category and it still hasn't hit American soil. You can request that your yaris come in with a TRD Rear sway bar. When it hits NY PORT or whatever port your region receives yaris from it will go into a second assembly line state side where they will put on your Sway bar and Floor mats and whatever else toyota wants put on there. The Yaris will come into the dealer with the sway bar listed on the window sticker and if you print off the Vehicle inquiry then or 10 years from now in the Dealer Trac system it will list the Sway bar as an option on that vehicle. As for my wheels yes they are .5" too wide but they were approved by my regions solo chair and I do know if I went to compete in another region or at a higher event they may not pass but I am not running wider tires and I'm not even running slicks so I did so with the blessing of my regions SOLO chair.
#2 | ||
Start another Oil Thread!
if you order a swaybar with your yaris and it happens to get installed at the port, it is NOT a factory option. the only port installed options that are legal are parts that can (AND WILL) be installed at the factory. in other words, you order a yaris with ABS, and the factory does not install it for you, but the port does. THAT is legal, because the factory DOES install ABS on a yaris. but the factory does NOT install rear swaybars, so it's not legal in stock class, no matter who installed it. i wanna fly to NY just so i can contest you now
you nailed it sir.
| When did you experience your first mechanical failure? How serious was it? | twowheels | General Yaris / Vitz Discussion | 40 | 08-21-2009 03:38 PM |
| anyone else serious about a IQ trade-in this summer | regal | General Yaris / Vitz Discussion | 34 | 06-03-2009 12:29 AM |
| Pictures from Autocross at FedEx field in landover MD (autocrossers inc.) | BrazdonW | Photo-Video-Media Gallery | 16 | 04-14-2009 01:29 PM |
| Obama topic SERIOUS | Bob_VT | Off-topic / Other Cars / Everything else Discussions | 6 | 12-11-2008 05:16 PM |
| Yaris 2001 - serious problem | adnanmalik | General Yaris / Vitz Discussion | 10 | 06-19-2006 09:59 AM |
