dulcidude
instrument cluster on door post
Does anybody know a manufacturer who makes the plastic molding you can fit on the front door post that would hold a tach? For some reason my Yaris stick shift didn't come with a tachometer. Drilling holes in the dash won't happen on this car so any advice would be helpful
#2 | |
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
![]() ![]() ![]() ![]() ![]() Drives: Decepticon - Ravage Join Date: Nov 2008
you're talking about an A Pillar gauge pod? You could always just double side tape one down above the air vent.
![]() Check out my Build thread: http://www.yarisworld.com/forums/showthread.php?t=52274 |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
get a Garmin (no other brand, get a garmin) Nuvi suction mount and
slap that on the driver door A pillar mini-window. then mount gauge to that. Eventually it will fall off on it's own. that will be 3 or 4 years. so when that happens just stick it back on. Garmin mounts are THE most solid. |
#5 | |
she was an American girl
Take a look at this though.
I've considered it for my car but I just don't have the time right now so I haven't ordered it... http://www.amazon.com/06-Toyota-Lift...6586990&sr=8-1 |
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
I've seen the glow shift gauges pod A pillar piece multiple times. i'm sure there are other companies that make them as well.
it adds a unique look to the car though so the OP might not like it. it's definitely more of a racer or tuner look for the car. |
| Instrument cluster light | chriscruz2006 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 08-26-2014 11:29 AM |
| Sedan Instrument Cluster to LB Instrument Cluster | Malaya1221 | Cosmetic Modifications (Exterior/Interior) | 2 | 12-02-2008 10:05 PM |
| Instrument Cluster | Stoln | General Yaris / Vitz Discussion | 2 | 06-23-2007 01:43 AM |
| instrument cluster swap S -> LB | elo79 | Performance Modifications | 1 | 12-21-2006 10:22 AM |
