#19 |
![]() Drives: Future Yaris! Join Date: Oct 2009
So Im still left with the question... would it be beneficial at all to build little sealed boxes for the rear speakers?
#20 |
Drives: 2009 TOYOTA YARIS SEDAN Join Date: Aug 2009
Nope.
#21 |
Roadrunner Jr.
I'd agree with that last post.
Personally, I enjoy the bigger woofers. I get to settle for dual ID 15"s sealed. Taln, I really do want to hear the enclosure you're rocking! You know, I've got a couple classical pipe organ pieces that have some magnificent LOW bass passages...
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#22 |
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
My vote is to get high quality speakers with maybe 1 amp to power them and to just crank the bass setting on your head unit.
You're not likely to get vibration-inducing level bass out of speakers but you can get very adequate bass and even more if you change the equalizer settings during playback. You're going to have to decide what's best for you: 1) solid speakers w/ amp 2) give up and save your money 3) quick release amp / sub setup Personally? I started out with a huge audio system and loved it but ended up tearing it out because I started getting into performance. If I were you I'd just save the money and if you haven't already, install high quality aftermarket speakers to replace the Toyota OEM ones. I bought 4x blaupunkt speakers with my audio system and they sound great. Got a hell of a price on em too. |
#23 |
Drives: balck car Join Date: Sep 2009
I have component speakers in the front. So 6.5 mid drivers in the door and tweeters up on the door sails. And then 6x9 coaxials in the back. I have the speakers wired thorugh a 4 channel amp to give them more power and then front set on HP and rear set to LP so you get more mids and sometimes lows so you get actually pretty good base. Its enough to rattle my rear view mirror down and have to adjust occasionally. Without dynomat though in the doors it does rattle the doors significally. I cant have any bottle water in the holder. Its not earth shaking but is not too bad.
#24 |
![]() ![]() Drives: 4 door hatch Join Date: Oct 2008
You'd be surprised on how the small bazooka tubes sound. And they hardly take up any space.
#25 |
37HSSV
to add a point, you dont have to keep the subs in the car for autocross, if its a big bulky box that isnt fixed to the car, you can always remove it. wires left behind would weigh a lot less than leaving it in, or building fixed boxes behind speakers, or whatever. Just do it right the first time, allow it to be removed. Then you found your happy medium between both worlds..
Just dont complain about having to remove it.
07 Toyota Yaris Hatchback -sold- 11 Mazdaspeed 3 -SRI/TIP, 3 inch TBI, Custom FMIC, Tuned by Cobb Accessport, HKS ssq2 BOV, Upgraded HPFP- Clean stock look... Killer performance. |
#26 | |
Audio Junky
If you have an automatic, I'd say build some fiberglass kidpods, throw something like a Tangband neo 6.5" sub in each one, run those pods sealed, and get a 80x2rms amp to power them. then run your normal doors speakers off a 50x2 rms amp and call it good. |
#27 |
![]() Drives: '08 Yaris sedan Join Date: Oct 2008
If space and weight is really an issue, i'd recommend that you do a proper infinite baffle install on your rear dash with a pair of eights a single ten or even reuse the factory 6x9 cutouts for a pair of tang band or CDT 6x9 subs (parts express)
#28 |
![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Apr 2007
#29 | |
Audio Junky
I didn't know CDT made dedicated midbass drivers in the 6x9 size... not many companies do that. |
| Running Firewall Power Wires for subwoofer | MacMaster761 | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 03-06-2010 03:04 PM |
| Yaris Subwoofer | shtou | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 12-18-2009 12:04 PM |
| Bass inside the car, not outside. | skigil | In Car Entertainment + Electronics (audio / video / alarm) | 28 | 10-30-2009 03:03 PM |
| Kenwood KSC-SW1 Powered Subwoofer | seriousfun | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 04-02-2007 02:44 PM |
| Your Ultimate Playlist | eflb55 | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 12-18-2006 09:43 PM |
