Old 11-01-2009, 02:05 PM   #1
german yaris
Drives: 2005 Yaris TS 1.5
longer 5th gear
Is there outside anywhere a publisher who have a longer 5 th gear for the yaris Ts P1? Or is there any other Toyota gearbox from where the last gear is fiting in the Yaris gearbox? On 190kmh the car has over 5000rpm thats too much
german yaris is offline   Reply With Quote
Old 11-01-2009, 02:23 PM   #2
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Try fitting larger diameter tires.
Old 11-01-2009, 02:28 PM   #3
frownonfun
frownonfun's Avatar
who's going 190kmh (118mph) and why?
I crush you like tiny clown car, because you are clown, yes?
Old 11-01-2009, 03:02 PM   #4
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Wir fahr'n fahr'n fahr'n auf der Autobahn
Old 11-01-2009, 03:20 PM   #5
german yaris
why? because we have no speed limit....
Old 11-01-2009, 09:53 PM   #6
frownonfun
frownonfun's Avatar
outstanding. autobahn. germany. didn't put that together at first. cool.
still i don't think the yaris was meant for high speed autobahn driving. but hey, if you come across a longer 5th more power to you.
Old 11-01-2009, 11:55 PM   #7
tomato
tomato's Avatar
190km / hr?
Old 11-02-2009, 12:48 AM   #8
curik
Drives: 06 yaris AT
http://trdparts.jp/english/list_race-mis_ncp13.html. Seems like there is no longer final drive for the yaris...
curik is offline   Reply With Quote
Old 11-02-2009, 02:56 AM   #9
JBougie
JBougie's Avatar
JBougie is offline   Reply With Quote
Old 11-02-2009, 05:51 PM   #10
german yaris
Here that isn`t much. My Yaris drive 205 @ GPS testet. But then other cars drive one meter behind you, use the horn, lighthorn, and flashlight. They always drive "buisness class Combis" like Mercedes, Audi, BMW.....
Old 11-02-2009, 06:15 PM   #11
fmicle
fmicle's Avatar
190km / hr?
Yep, a few years ago, while living in Germany I rented an Audi TT for my birthday and drove it 215 km/h on the Autobahn, just to see how it feels. That was the max speed marked on the speedometer anyway and it could have probably gone faster, but I was too chicken I only did it for less than 3 minutes anyway, just so I can check it off my list (drove 215 km/h - check)
fmicle is offline   Reply With Quote
Old 11-02-2009, 06:17 PM   #12
fmicle
fmicle's Avatar
Ich vermisse Deutschland
I miss Germany
Old 11-02-2009, 11:39 PM   #13
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Jesus, 200km/h? Pop a tire and you'd do many barrel rolls
Old 11-03-2009, 04:22 AM   #14
andries
aka Jack Wolfskin
Drives: Yaris
Send a message via MSN to andries
Hey, my 1.8 TS make more revs on that speed. It's no problem for me. The engine can have it.
By 205 km/h (GPS) it revs 6281 rpm. ( also on the German Autobahn)
BTW
Mabey a gearbox from a diesel have a "longer" fift gear a you can put him in your gearbox.
andries is offline   Reply With Quote
Old 11-03-2009, 01:37 PM   #15
german yaris
but I have 1,5l, not 1,8. I have the older Modell.
here you can see it http://www.yarisworld.com/forums/sho...p?t=51&page=47
@ fmicle Habe dir ne PN zurückgeschrieben, bei uns kannst du auch 300km/h fahren.... :-)
Old 11-03-2009, 04:00 PM   #16
andries
aka Jack Wolfskin
Drives: Yaris
Ja, ich weiß. aber vielleicht der fünfte Gang des P1 Diesel länger, und kan er in ihre Getriebe montiert werden.
Old 11-03-2009, 04:07 PM   #17
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
TRD Japan actually offered a shorter and longer gear ratio option for the C56 tranny on your 1st gen TS. You would probably have to get it from japan and it would be pretty expensive.
A MUCh cheaper and feasible option is to get an used tranny from a US spec Toyota ECHO.
It should be a direct swap and the gear ratios are way longer! (meant for US highway driving and fuel economy)
Old 11-03-2009, 04:48 PM   #18
If you have a TRD part number, I can get it from Japan.
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 12:51 PM
July 5th Mosport DDT lapping event, 1:00-5:00pm! 2009-7th Touge.ca lapping event! Touge.ca Canada 0 06-04-2009 07:47 AM
New Owner - Lights on Gear Shift javagirl New YARIS Purchase Forum 8 05-22-2009 03:23 AM
Is using 5th gear at 40mph messes up my engine? Syroyizhka General Yaris / Vitz Discussion 30 04-20-2009 08:59 PM
clicking into first gear tekmoe General Yaris / Vitz Discussion 9 11-01-2006 03:44 AM
