Old 12-13-2006, 12:08 PM   #4
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
I wanted to hold off on dropping this info until I figured it all out but apparently the 2zz engine is a direct bolt it with very few mods required, one being a front motor mount and obviously the wiring. I had a website for a shop in the US that does these swaps between corollas, camry's etc on a regular basis and understand and know exactly whats involved with the wiring harness - unfortunately I either have the link at home or erased it from explorer (looks like Ill have some searching to do). All I do know for sure is you have to have to whole harness from the donor car including ECU. Ive seen engines from the Celica, Matrix, Corolla and even the Pontiac Vibe used in these swaps. Try a google search for 2zz-xx engine swaps. Just curious but what engine are you swapping in? If I can find a donor car cheap enough next year I will try this swap rather than going FI on the stock Yaris. Post up details where you can. Im going to try and find that link...
mikeukrainetz is offline   Reply With Quote
