Old 11-24-2009, 11:32 AM   #91
Indianspringsaz
Drives: 07 Bitchin Blue HB
Originally Posted by TheSilkySmooth View Post
The yaras 1NZ engine can be hard on the oil due to the inverted bucket tappets and the cam chain drive. Luckily the valve spring pressure is really light - IIRC about 40LBS closed - but you can still get galling of the lobe due to high ramp rates and mass acceleration at high rpm. The problem with PAO based synthetc is its not a good lubricant. That includes most amsoil and Mobil 1 (at least the M1 with majority PAO base), DIesters POE and AN synthetics have much a better inherent lubricity and polarity that PAO based syns lack. Source Motul and Fuchs silkolene for the "best" synthetic oils.
First I have heard of this. Would you post some references? I am interested in oils, and always learning something.
07 Yaris HB
07 Road King
06 Superduty CC
05 Scion TC
01 30' Sleekcraft HP500EFI
Your Local Amsoil Dealer
Indianspringsaz is offline   Reply With Quote
Old 11-25-2009, 12:23 PM   #92
Henry G.
Drives: 2008 Yaris HB
I agree ester synthetics are superior, but I dont think its fair to says PAO synthetics aren't good lubricants. They are. Oil has come a long way in the last 20 or so years.....
Henry G. is offline   Reply With Quote
Old 12-03-2009, 02:48 PM   #93
TheSilkySmooth
TheSilkySmooth's Avatar
Haunt BITOG and NORIA forums for more info and trashing than you can stand.
Old 12-03-2009, 02:53 PM   #94
TheSilkySmooth
If you research further and look at unadditised testing of PAO v. group II and POE and diester you will find that lowly group II oil is a better lubricant than PAO by far. PAO is not stable at high temps and will oxidise thicken and varnish. It does not solubilise important additives at all. It doesnt stick to metal being inherently nonpolar. It s probably servicable at extremely low temps with healthy and complex additisation for low stress application. Not a "race" or "sporting" oil by any stretch.
Old 03-15-2010, 03:40 PM   #95
sbergman27
sbergman27's Avatar
Drives: 2008 Yaris Sedan
Thanks for the info. Would you mind posting a few links to data supporting that?
sbergman27 is offline   Reply With Quote
NEW PRODUCT! SIMOTA DROP-IN REPLACEMENT FILTERS kargoboy YarisUniverse 10 01-21-2009 08:48 AM
Drop in performance air filters which is best? YarisSedan Performance Modifications 14 11-07-2008 09:52 PM
SRI or CAI YogiYaris Performance Modifications 21 05-03-2007 11:28 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
Darn Workplace Internet Filters...! Yaris Revenge Off-topic / Other Cars / Everything else Discussions 18 08-01-2006 08:30 PM
