#1 | |
Nothing beats a Toyota!
Drives: 2013 Yaris 5 dr liftback Join Date: Jan 2009
I have a question.....would it have been worth a few dollars more to have someone come to your home...or work place....and change your oil? I have toyed with the idea to start a valet oil change business that specializes in full synthetic oil and comes to where ever it is convenient for you. How many would pay $100 for that?
Big Dave Indianapolis, IN Synthetic Oil....its in my car.....for at least 10,000 miles! ![]()
![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
I would certainly recommend learning to do it for yourself. The oil change on the Yaris is not hard as engines go. You can even do it without jacking the car up. (not the most comfortable approach) The trickiest part is finding a filter wrench that will fit the little tea cup of a filter it has and not slip. Proper filters and oil can be found in any parts store or even Walmart.
If you don't have the Saturday morning to spare and a suitable garage or driveway, you can look for an independent shop. Try http://www.cartalk.com/ct/mechx/find...63101&miles=50 if you have no one local that can recommend a shop. There is nothing magic about dealer service. In many locations independent shop mechanics pass the same certifications the dealer staff do. If you are worried about warranty, just keep your receipts on file. Quick lube places are another story. If you have no other choices, look for one that has certified staff (on hand if not under your car) and where you can watch the service being done. If you use one of these, you should check the level and fittings when you get home. (making it less of a convenience perhaps, but keeping your engine safe) |
would think synthetic be better for the 1.5 ltr. engine due to working harder to climb hills and highway speeds ( higher r.p.m. ) . Be better for very cold day starts and those hot commutes in summer .
Uhhhh Missouri does get pretty cold.
Idk what your standard of cold weather is but single digit temps is pretty darn cold in my eyes. I would think synthetic oil is justifiable in those conditions. Also, unless the average oil changing chain is losing 50ish bucks every oil change they make, there is definitely a profit in an $80 oil change... if they really were losing that much each change, those places would not exist... 80 is absolutely crazy to me... |
![]() Drives: 2010 Yaris Blcksandpearl sdn Join Date: Dec 2009
synthetic oil
What I have been led to believe by visiting different forums (bob is the oil guy and cartalk, primarily) is that synthetic is superior to dino oil in extremely cold temperatures (like -20 F and below) not single digits. Dino oil can handle single digits. Also, synthetic is important for high performance engines and any engines for which is it specified in the owner's manual. The question is whether or not synthetic oil is beneficial for an engine like the one in the yaris. The Yaris owner's manual does not specify synthetic. I'm not knocking anyone who uses synthetic oil in their yaris (it's your baby, I understand) but if the OP is complaining about a high price oil change, I just wanted to put it out there that he/she might just want to use dino oil. I only have 2200 miles on my yaris, but I plan on using dino oil when the time comes to get that first oil change.
Half a Bubble Off Plumb
Yep. Dino oil at recommended change intervals is what my Yaris is getting, and I expect my engine life to be as good as anyone's.
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
Uh, no, that's not so overpriced. I've been upset with the price of synthetic oil change myself, but if you're asking for full synthetic, that's within the price range. At walmart or auto-zone, the top brand full synthetic will run 35-45 dollars, some of them closer to $50 (Mobil-1). + filter, + labor, and you're there. If I'm going to do it myself I'd still spend $60 in 'parts'.
#8 | |
Anybody that thinks a dealership isn't ripping them off is clueless. A dealership is the LAST place that I would bring a car to be worked on. Any mechanic(s) that is worth a shit is working for themselves as an independant garage anyhow. Dealerships have been called "Stealerships" for years now and it's no coincidence. The argument for synthetic is better lubrication and cleaner engine. There is no question that a synthetic is superior to a conventional in those two areas. I believe their ability to suspend particulates and harmful combustion bi-products may even be superior but I haven't done the research to say that with confidence.
^ I agree with saying that dealerships in general over charge,but saying that all mechanics that don't work for independent shops aren't "worth shit" is a little over the top... Not to mention incredibly rude and mean.
As somebody once said...the truth hurts. Good Mechanics work at independant garages because independants can't afford bad or average mechanics and dealerships simply don't share the same stakes because lemmings come to dealer over and over regardless. Simple as that...
#12 | ||
And you're also acting like a lube tech works on one car, and one car only until its done. Like he sits there and watches it drain or something. When working in a shop, you know full well a lube tech can and will do as many cars as there are lifts or pits. I realize its convenient to fudge the facts to support your business, but nobody is buying it. Quote:
I browse the kragen ads too dude.. |
![]() ![]() Drives: S sedan Join Date: May 2009
$86 for an oil change + tire rotation? It seems steep IMO. Maybe it's time to invest in a floor jack & a set of jack stands (plus a decent torque wrench & a metric socket set).
It's really easy to change oil in Yaris compared to some !!@# cars out there. As for full synthetic vs. dino oil... I really don't see a huge difference between the two, but I drive my Yaris only during summer. |
Drives: 2009 TOYOTA YARIS SEDAN Join Date: Aug 2009
Yeah, I just did my 5000 mile change... it was ridiculously easy and I probably could have done it without the ramps. Though I do wonder why they angled the drain plug towards the right wheel.
Learn to Relax
Aha! Good call...
My Little Blue Egg :)
Drives: '09 3 door Yaris Join Date: Dec 2008
I paid 60 dollars for my synthetic oil change.
#18 | |
![]() ![]() ![]() Drives: 08 sedan at Join Date: Dec 2008
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 06:58 PM |
| MJ dead | 90tsi | Off-topic / Other Cars / Everything else Discussions | 28 | 06-26-2009 02:20 PM |
