Anti theft "chip" in the key?
Does anyone know if this chip exist in the key? The antitheft immobilizer that the cars computer must recognize. I want to have a remote starter installed and the alarm installer is saying I need a bypass module. Can anyone confirm if this is needed?
Can anyone recommend a good outfit in the Dallas/Frisco area to install it? |
No. There is no chip in the Yaris key. This is at least true for the non-keyless entry option. You can have duplicates made anywhere, including Walmart, and they will work in the door as well as the ignition. Doe's it cost extra for this bypass module? Don't let them take you for a ride.
Test it your self. Have a cheap key made and try to start your car with it. If it starts, no chip. If it turns over but wont start, you have a chip. |
![]() ![]() ![]() Drives: 07 Meteorite Metallic Yaris LB Join Date: Jul 2006
the chip/immobilizer combo is only present as an option in the sedan, it is not installed base in the sedan, nor is it availiable AT ALL on the liftback, I'd say your installer is trying to take you for a ride, confront them about it and suggest you might take your car elsewhere.
thank you for the information. i will commence with the install with no bypass module required. wish me luck
HardlyDangerous
Drives: 09 Yaris LE, H/B, auto Join Date: Jul 2006
I know for a fact the immobilizer comes standard on hatchbacks and sedans with keyless here in Canada
The early bird gets the worm, but the second mouse gets the cheese. |
in canada, it's the option of a key RECOGNIZER. so the car will start as long as it's started with the correct key. ie, if you try to start the car by hardwiring, it will not work. i think it's pretty useless.. |
I understand it is available in Canada, but the Key Transponder/Immobilizer is not available on any United States Yaris Liftback, and the poster was a Liftback owner from Texas, so his alarm installer was trying to bullshit him.
der Zeck
Not realy we special ordered a 2nd liftback loaded to the max, that DID have the immobilizer key, we ended not getting the 2nd car and bought windows for the house instead
*EDIT* I'm not going to argue the point.*EDIT* I'm just trying to save this guy from getting fleeced by his alarm installer, the only case in which you may need to bypass an immobilizer is the keyless entry system, but it's not built into the ECU, so there are other ways around it besides a potentially expensive transponder bypass unit.
HardlyDangerous
Well I don't know exactly how it works... I just know the car won't run on a steel key cut from the hardware store.
I have to use either my MASTER keys (i ordered a second master for $200)or one of the two black OEToyota keys. I also know if a key or key ring is sitting on top of the fob when the car is running it will shut off. The keys must hang below the fob.
My car starts fine with the steel hide-a-key I had made at Walmart.
However, due to differences in Canadian/US models and special order options, I believe Fazali needs a second opinion from another installer. |
#13 | |
Engineer/Artist/House-Dad
Drives: 2006 Toyota Sienna XLE Join Date: Aug 2006
--B
His: 2006 Toyota Sienna XLE Arctic Frost Pearl, FC Package, 2007 Solara Nav unit, Spoiler, Running Boards & Auto-dimming rear mirror Hers: 2007 Toyota Yaris LB Black Sand Pearl, Auto, Power Package, Side Airbags, VIP security, USDM center armrest, and accessory 7 spoke 15" alloy wheels |
#14 | |
Just to update people, this only refers to USDM LIFTBACKS... I checked with my parts department today, only ONE key is specified for the US LIFTBACK, the non-transpondered key, unlike the SEDAN which has p/n's specifed for a non- and a transpondered key. Just to double-check, we ran the VIN of a fully loaded liftback on the lot, and the p/n specified was the non-transponder key. We even checked with another Toyota dealer in a nearby town, their parts computer said the same thing. |
The chip does exsist
I notice in your User tag you are a SEDAN owner, so I refer back to what I just said.
The person who was asking this question is a LIFTBACK owner... they are both CALLED Yaris, but these are two different cars, with two different sets of specifications and options, people seem to forget this. |
You better calm yourself buddy because on his opening post he doesnt specify liftback or sedan...I have a sedan that has a Remote Start Clifford alarm that cost $400 and 50 additional because they had to install the module because of the chip in my key if there is anything i know is about this and next time you wanna get smart you should read how there is no info about him having a liftback in his opening statements
its EF LB 55
Drives: Toyota Yaris 2007 Sedan (US) Join Date: Sep 2006
Ya.. Drives: 2007 Toyota Yaris LB
He didn't say that he noticed it in the opening post. Regardless when I went to the local shop they said they are going to use my valet key to do the bypass. They weren't sure if my car needed the bypass and told me to turn it on and look to see if there was a key symbol when I started my car up near the spedometer and there was. I guess that is the key immobilizer. If it wasn't so damn cold out I would grab my manual and see what that symbol means. Edit: I don't know what that high-on was talking about. It's an engine temperature thing, has nothing to do with the immobilizer. But in my manual it says that if the red light on the dash is flashing after I turn the car off, the system immobilizer is on there. It also says "The engine immobilizer system is a theft prevention system. When you insert the key in the ignition switch, the transponder chip in the key's head transmits an electronic code to the vehicle. The engine will start only when the electronic code in the chip corresponds to the registered ID code for the vehicle." Bingo? Edit Edit: No flashing light. I think they are trying to pull a fast one on me. Last edited by eflb55; 12-26-2006 at 09:09 PM. |
| remote and key not together as 1 | manborn | In Car Entertainment + Electronics (audio / video / alarm) | 20 | 10-20-2006 12:23 AM |
| toyota vip rs3200 alarm system and key with integrated remote | manborn | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 10-16-2006 06:02 PM |
