Old 01-30-2010, 07:08 PM   #7
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
When I'm cruising on level ground at around 20 MPH, I often find that the slight amount of power needed to maintain the speed is so close to idle power that it cuts in and out of DFCO, causing a surging effect. When the fuel cuts completely off in DFCO, the car suddenly starts gently decelerating, and on giving it slightly more gas, the power abruptly cuts back on and it surges ahead. It is normal. There's no gradual fadeout from idle power to DFCO, which is negative idle power. It abruptly switches states. It's a minor nuisance. Can't be "fixed." It will be more exaggerated if you push the pedal harder when the DFCO cuts in than if you barely ease it on, as the engine will suddenly start producing power with the throttle wider open.
Head Unit Suggestions MitchEvious In Car Entertainment + Electronics (audio / video / alarm) 0 03-22-2009 08:55 PM
new user with a couple of problems grant_nelton Great Lakes 8 03-13-2009 10:18 PM
Problems? Twistoffate0817 General Yaris / Vitz Discussion 35 12-24-2008 11:53 AM
Timing chain, sprockets, & cam position sensor problems? PetersRedYaris DIY / Maintenance / Service 8 01-04-2007 11:50 AM
