Old 01-31-2010, 10:20 PM   #18
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
Bankrobber,
If this is a "sudden" development I would do as advised and check for leaks. I too am curious since the filter was changed 1500 mi ago did you check the oil after running the engine ? Sometimes people forget the newly installed filter is empty until the engine is run for a few seconds..
I wouldn't worry about consumption until it establishes itself as a pattern and wouldn't use that alone as a reason to switch to conventional.
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
