Old 02-19-2010, 08:21 AM   #11
MadMax
MadMax's Avatar
The first (and easiest) mod you should do is pop the cap over the bolt on your rear wiper and remove the little tab. That'll allow you to pull the wiper all the way out to clean the back window (it only lifts a few inches with the tab).
The second mod is the $12 exhaust tip from Walmart. It's the larger one they sell, and it not only looks better than the stock exhaust pipe but it actually adds a little "growl" to the car!
The third mod should be frameless wipers, but this requires a little work as few companies make a 14" one for the passenger side. However, you can buy a 16" one and cut an inch of both sides. It works really well.
There are threads on all of the above, search for them if you need more info. Otherwise, enjoy your Yaris, it is a great little car!
Oh, and since you have an auto, be careful not to accidentally kick it out of drive (D) into third (3), as it will have a detrimental effect on your gas mileage! However, you can intentionally shift down to third when decelerating to kick in the DFCO (deceleration fuel cut off)
Cheers! M²
