Old 02-19-2010, 03:21 PM   #11
shastatodd
Drives: 2009 RED Yaris
Originally Posted by bobolinko View Post
this is the simplest fix.
I used the right side (unused) Original Headlight socket to make these connections.
50 cents and done in a jiffy. If you want to make it "professional" looking. buy a connector from Radio Shack and fabricate the wiring on that, and plug it into the old harness.
The previous (cluster) "fix" did not work, but this one (the under hood fix) did resolve the issue. I DID use the 10K ohm resister in series with the gray instrument cluster wire to dim the overly bright blue high beam indicator... so this is a bit of a hybrid method taking the best of the two fixes for the non-functional high beam indicator problem after the HID conversion.
Todd
shastatodd is offline   Reply With Quote
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 09:49 AM
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 02:33 PM
Hi & Lo Beam HID Conversion Kit OgDogg Items for Sale by private party 0 11-11-2008 04:55 PM
