I got this offer too:
This is the message that was sent: *************** i have an mb quart dsc 480 80x4 or an eclipse xa4000 125x4 both brand new in box. mb quart is 100 plus shipping the eclipse is 200 plus shipping. |
Secret Agent
Drives: 2008 Yaris Hatch Join Date: Feb 2009
I didn't like the signal-to-noise on the MB Quart amp.
That cheap SPL had better specs, but who knows if you can trust those numbers. "Numbers" get played with all the time. That DIYMA site looks like a bunch of hackbobs pawning their junk. Deal with a reputable business. Not some joe-schmoe on the internet.
www.sonicelectronix.com for all your mobile audio needs! |
Help/advice Matching amp to subwoofer...
![]() I'm having trouble understanding about Ohms, # of voice coils, etc. Matching Amp to sub-woofer seems to be very important... So what if I get a Pioneer Digital Series Class D Monoblock amp! what would be a good SQ 12" or 15" subwoofer to match this amp? Or is this a good amp to hook up 1 of my old Solo-Barics? ["single voice-coil sub", 8ohm] LINK to amp specs ![]() GM Series Class D Monoblock Car Amplifier RMS Power Rating: 4 ohms: 300 watts x 1 chan. 2 ohms: 600 watts x 1 chan. Max power output: 1200 watts x 1 chan. MOSFET power supply Wired remote bass level control included Variable bass boost (0-12 dB at 50 Hz) Balanced isolator input circuit Speaker-level inputs with included high-level to RCA adapter Heavy duty aluminum alloy heatsink Chrome-plated RCA level inputs Chrome-plated screw terminals Variable low-pass filter (40-240 Hz, 12 dB/octave) CEA-2006 compliant amplifier Frequency response: 10-240 Hz Dimensions: 11-3/8"L x 7-7/8"W x 2-1/4"H I appreciate every single input... thanks |
![]() ![]() ![]() Drives: 2010 Meteorite Metallic LB Join Date: Feb 2010
That amp needs to be at 2ohm for 600 watts so the ideal solution would be a sub with either a single 2 ohm voice coil or dual 4 ohm voice coils. Either way would give you 2 ohms. You could also run it at 4 ohm but you will only get 1/2 the power you get at 2 ohms. If you wanted to use your Kicker subs you can hook 2 of them up and get 300 watts (150 each) or hook all 3 up and get roughly 500 watts (166 watts each roughly).
#6 | |
12" Dual 4 ohm Type R Subwoofer Power Handling: Peak: 1800 watts RMS: 600 watts LINK
Just a Herbicidal maniac.
Drives: 2008 Yaris S Sedan Flint Mica Join Date: Oct 2008
I've got the 10" version of that puppy (thanks to Alien Mantis's suggestion on my build thread) and I'm VERY happy with it!
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace. |
That would be a great choice. Do you have any local shops that sell Alpine? I would match that price all day long and if you blew it up you could exchange it over the counter.
Roadrunner Jr.
Responding to AM's thoughts on the different enclosures...
He's absolutely right. You can absolutely get good sound out of both. I should PROBABLY be using a vented enclosure on my sub with the amount of power I have. Instead I'm keeping it sealed. Hell, I'm even looking at an 18" woofer. Maybe around Christmas I might do another enclosure...
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
Secret Agent
I knew an audiophile guy who was a recording engineer.
He always said, "there is life below 40hz" ( maybe for HIM )
Roadrunner Jr.
Oh hell, I cross my mid bass at 40 Hz...I can definitely say that there is life below 40Hz
#13 | |
Me too! but at 63 Hz... I know your L8s must sound amazing I only have cheap 6.5 drivers even though the midbass is great (I never realized about it, but I've been missing this frequency in my old installs that all songs sound so different now) and WOW! I've been learning so much about mid bass that I understand now when you say that it's so important for a good sound system. with some songs I mute the subwoofer and I can't tell the difference, then I mute the midbass and turn on the sub again and sounds like crap! the mid bass does all the job! last but most important... Sqcomp! I'm going to give up! you are absolutely right, go with kick panels on the floor for midbass drivers, my doors are driving me crazy, I tend to rest my left arm and knee on the door panel and buzzes so much (no rattles, just vibrations) so I'm going to make some small kickpanels. I got some used 6.5 drivers (not high end, I can't remember the brand and specs) but hopefully one day I'm going to be able to afford HAT L6's ( I think they go for $500-$600) for now I'm going to experiment with these little 6.5 woofers in kickpanels. Man! this is like "THE NEVER ENDING STORRY" just like you thinking about an 18 in sub for Christmas.! Thanks again guys! all your input helps me gain knowledge and correct my mistakes I hope helps others to understand how everything works. |
#14 |
Secret Agent
Yeah, this is turning into a soap opera.
Or worse.... a reality TV show without the TV!
#15 |
Thanks everybody, lets see what happens at the shop, they call me and I'm going to stop by this week.
. CLA 250, 4MATIC |
#16 |
Roadrunner Jr.
Absolutely experiment. I did a bit of planning when it came to door panels versus kicks. What you trade is space versus performance. I'd rather have performance.
I've taken apart the door panels multiple times. With some work you can quiet them down. You're tending to lean on the silver door control panel/insert piece or the top of the door sill aren't you?
#17 |
YES! And the vibrations after a while are terrible very itchy. No noise at all or Rattles it just vibrates! I guess having the speaker attached to the door just makes a bad speaker box.
#18 |
Roadrunner Jr.
Have you taken the control insert apart yet? You can put sound deadening on the edges of the panel to reduce the vibration.
I'd send you mine if you want. I have no problem re doing the inserts...although you'd be out your window controls until I got you mine.
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
