I've been so busy, and this weekend we have BOO-BOO, and Fiambre
(Guatemala tradition of a one-of-a-kind food that we only prepare once a year) any way... I did a little bit of sanding and located the areas on the spheres that needed some reinforment, also added some plywood inside where the a hollow male nipple will hold them in place, the wires will go through. ![]() ![]() male nipple: ![]() D. |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
What fuse have you used for the power wire from alternator to battery ?
And if i put a 2nd battery in the trunk....i plug tthe red to alternator and the ground to body....like the one in the the hood ? thanks A.
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#3 | |
![]() I din't put a 2nd battery, I don't really need it, my voltage with 3 amps shows an average of 13.8 volts most of the time. |
Roadrunner Jr.
D,
You could also look at thread-serts. They're like the ones I used in my A-pillars for the L4 baffle. Also, take a look at what I have access to: ![]() Something tells me you may want this reference disc? I can burn you a copy...
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine Last edited by sqcomp; 10-30-2010 at 05:24 PM. |
I went to Lowe's to get the "nipple(s)" but it won't work, by the time I get all the nuts and washers it gets too big, I may not be able to fit the 3" driver in the sphere.
I'm going to have to make 2 holes one for a bolt and other for the wires. Sqcomp tells me to use thread-serts so I'm digging more about it. D. |
Some thing like this is what I'm looking for...
Roadrunner Jr.
![]() ![]() Look into the holes... It will couple like this: ![]() You see the ones I got? The two pictures on top? Those are actually inserted with an allen wrench. That makes it SUPER simple. Look around at the harware stores locally. If you have a good one, they'll have these. As a last resort, I can get you these.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#10 | |
Thanks, I'm still shopping around for a mechanical system to attach the spheres to the A-pillars, I have a few ideas but nothing tangible D. |
Roadrunner Jr.
Let me know. Perhaps we can brainstorm something up.
Thanks sqcomp. It's nice to have a friend with crazy ideas for a Yaris; just like Me!
![]() This is what I was looking for! I think it will work, and I'll be able to pass the wires through! ![]() I used hot glue to hold the sphere in place, now lets drill a hole and use the Lamp Nipples I got at the local hard ware store!!! ![]() ![]() ![]()
Roadrunner Jr.
Grumble
That just seems way too big. Imagine that a pillar. When you want to move or service that tweeter, how is it going to work? With the thread sert idea you will eliminate one of the nuts and washers that I see in the pictures above. Take that thread sert that I suggested put it in the side of the pod/sphere. Now mount it to the a pillar with a screw coming through the back of the pillar. You can put rubber washers on the backside of the pillar and in between the pillar and the sphere to decouple them from vibrations.
sqcomp, I understand what you mean... let me try this way because I want to have the A-pillars and spheres be 2 peaces, instead of molding them in "one" I'm more concern on the Structure of the A-pillar and how it's going to react with the extra weight! of the 3" mid driver; did you reinforce the A-pillar from the insde on the lower portion, it's kind of floating in the air by it self, there are no mechanical attachments in that area besides the 2 little guides at the bottom.
D. |
Roadrunner Jr.
I think you misunderstand me...
I'm thinking the same way you are, just with a smaller, simpler connection point.
#16 | |
Look what I did! D.
. CLA 250, 4MATIC |
Here is how it goes, little by little every night!
![]() ![]() ![]() ![]() Left side too: ![]() Behind A-pillar ![]() So far the aiming its right where Hertz-Audio recommends for the HL-70's ![]() Now it's all about SANDING AND SANDING! I'm going to detach the spheres and cover the A-pillars with plastic/tape then re attach the spheres... and work some BONDO... Yeah!!! I never have done this before so I'm exited. Then... more SANDING! D. |
FYI...
Now that I'm playing around with the A-pillars I can tell how much ENGINE NOISE can get into the cabin when these are not installed (A-pillars) If you ever take them out! stuff some foam in the lower corners where they meat with the dash board Also... just for FUN I took this photo yesterday, and my little ride shows up on the lower right corner! |
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
