#703 |
#704 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
So if i resume it...
Tweeter = those little black speaker with cross over Mid = 6.5'' in the front door Mid bass = 6x9'' ah the back Sub = 2 x 12'' alpine type R (which i'll buy) I amplify my mid bass , mid and my tweet...but i but a X over between the amp and the tweet and also the mid...or only xover for the tweet ? Thank you
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#705 |
#706 |
Oh thank you ! I really like YarisWorld everyone is helpful to everyone !! :D I'm impatient to see this :O
#707 |
#708 |
NICEEE I LIKE GRAPHICS !!!!! Thanks you so much!!!!
#709 |
I've been so busy, and this weekend we have BOO-BOO, and Fiambre
(Guatemala tradition of a one-of-a-kind food that we only prepare once a year) any way... I did a little bit of sanding and located the areas on the spheres that needed some reinforment, also added some plywood inside where the a hollow male nipple will hold them in place, the wires will go through. ![]() ![]() male nipple: ![]() D. |
#710 |
What fuse have you used for the power wire from alternator to battery ?
And if i put a 2nd battery in the trunk....i plug tthe red to alternator and the ground to body....like the one in the the hood ? thanks A.
#711 |
Roadrunner Jr.
D,
You could also look at thread-serts. They're like the ones I used in my A-pillars for the L4 baffle. Also, take a look at what I have access to: ![]() Something tells me you may want this reference disc? I can burn you a copy...
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine Last edited by sqcomp; 10-30-2010 at 05:24 PM. |
#712 | |
![]() I din't put a 2nd battery, I don't really need it, my voltage with 3 amps shows an average of 13.8 volts most of the time. |
#713 |
#714 |
#715 |
I went to Lowe's to get the "nipple(s)" but it won't work, by the time I get all the nuts and washers it gets too big, I may not be able to fit the 3" driver in the sphere.
I'm going to have to make 2 holes one for a bolt and other for the wires. Sqcomp tells me to use thread-serts so I'm digging more about it. D. |
#716 |
Some thing like this is what I'm looking for...
#717 |
Roadrunner Jr.
![]() ![]() Look into the holes... It will couple like this: ![]() You see the ones I got? The two pictures on top? Those are actually inserted with an allen wrench. That makes it SUPER simple. Look around at the harware stores locally. If you have a good one, they'll have these. As a last resort, I can get you these.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#718 | |
Thanks, I'm still shopping around for a mechanical system to attach the spheres to the A-pillars, I have a few ideas but nothing tangible D. |
#719 |
Roadrunner Jr.
Let me know. Perhaps we can brainstorm something up.
#720 |
Thanks sqcomp. It's nice to have a friend with crazy ideas for a Yaris; just like Me!
![]() This is what I was looking for! I think it will work, and I'll be able to pass the wires through! ![]() I used hot glue to hold the sphere in place, now lets drill a hole and use the Lamp Nipples I got at the local hard ware store!!! ![]() ![]() ![]()
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
