Free Mustache Rides
HID binoculars
So, I finally installed my HID kit yesterday, however, incorrectly. When driving around last night I noticed that the area in front of my car is black but the area above, below, to the left, and to the right is lit up. I saw the thread about that white headlight adjuster, but is that just for moving it up or down or can I some how aim them forward. last night i tried to pull the bulbs slightly out of the housing and it fixed the problem, but then it started burning the rubber water seal that it sits in and i couldn't get it to sit tight, instead it wiggled.
also, I am aware you lose highs, is that why when i flick the highs not only does absolutely nothing change but also the high indicator on the inside of my car (the blue light on my dash) does not light up. and when i twist the headlight stalk once forward my parking lights and the little bulb under the main light go on, then i switch it forward again the hid comes on but all the other lights stay on. HELP
If you installed H4 bulbs, they have a high and low beam. There are two kinds. Xenon low and Halogen high, in which the high beam really doesn't add much more light (but makes a less expensive kit), and true bi-xenon, in which you SHOULD see a distinctly brighter high beam.
Are you sure you oriented your bulbs correctly and that the wiring is all correct? What brand did you buy? Do you have a link to the product?
Free Mustache Rides
not sure, thought i followed the diagram correctly. it's an h4 kit, bixenon, from the barber.
Free Mustache Rides
oh, and it makes my radio staticky (sp?)
I'm not much on HID knowledge. Learning as everyone goes along here. It has been documented in other threads that the Hi Beam dash indicator will no longer function with HIDs installed.
JDM yO!
Drives: '09 3dr. 5-spd Join Date: Oct 2008
I have Bi-Xenons, and the highbeam indicator works as normal. Also with Bi-Xenon bulbs, it doens't actually throw "more" light out during highs, but instead, the cap slides forward and allows light to hit the bottom half of the reflector to create highbeams. So it's just alternating the beam pattern during operation of high/lowbeams.
because of the shroud on the hid bulb, it does cut the beam off at the bottom. my yaris is the same. i don't find it in any way hinders what i can see
high beam should pull the bulb back and give a more dispersed light vs the low beams....ive used these up north and theyre great. but they arent any brighter than the low beams, it just changes the light pattern by moving the bulb i have my lights angled down so im not getting flashed all the time, but it sounds like you've installed them correctly.
The Last Baron
Drives: 09 Polar White HB Join Date: Jun 2009
im sure that's due to a bad ground, proly from the install.
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires! | UR 19mm sway | |
| XenithXenon HID Conversion Kit | CorSport | CorSport | 0 | 09-03-2009 05:11 PM |
| Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast | phu@xenon-vision | Sponsors Classifieds Area | 8 | 03-06-2009 02:33 PM |
| KLight HID Conversion Group Buy!! $165.00 shipped!! | JRT lighting | Sponsors Classifieds Area | 4 | 11-20-2006 10:47 PM |
