#37 |
╚══════════RN
I had to fight really hard (for my road types, terrain, etc.) to get my MPG up past 40.
Mid to upper 30's is what I usually get, and seems to be about the norm with prudent driving. You're not doing anything wrong. If you did 55 on those roads, you would easily bump up past 40, but that's probably not safe, eh?
#38 |
Half a Bubble Off Plumb
Yep, your fuel consumption goes up pretty fast as your speed does.
#39 | |
Only Happy When it Rains
Colin Chapman disciple |
#40 |
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
Now that my car HB Yaris has gotten broken in(22000miles)with stock intake,exhaust and tires and wheels on it I am gettign constant readings of 40-42mpg.
In the spring when the intake,exhaust,and 17s go back on I am hoping it stays in the 35mpg range,last year it was in the 32mpg range with them on,and although still decent I enjoy my 40+mpg right now. |
#41 |
are your stocks the 14's or 15's? 17's kill mpg like you wouldn't believe.
#42 |
![]() ![]() Drives: '09 Yaris Sedan Join Date: Oct 2009
Does anyone shut the engine off at longer stops? I shut down if the lights have just turned red. I never hold up traffic for the sake of a drop of gas. Safety first. If you aren't moving and the crank is turning...zero miles per gallon.
I never hold up traffic driving 5 under either. I always try to at least maintain the posted speed limit on highways, too. This Yaris has also broken at least one major speed limit sign... doc |
#43 |
I don't shut it off at traffic lights, but do in drive-through lines.
#44 |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
7000 miles on the yaris now
on a 135 mile route, that I maxed 38.9 mpg at [600 miles on the yaris....] in 'as close to identical conditions' (temp, winds, speed)... when I did it last night I got 41.1 mpg tailwinds no, traffic same, car is 60 lbs heavier.... |
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 06:31 PM |
| Why is my new 09 Yaris MPG is so low | soup1207 | Fuel Economy Forum | 34 | 06-12-2009 03:45 PM |
| Help me see 55 mpg! | Loren | Fuel Economy Forum | 76 | 04-02-2009 04:23 PM |
| Anyone from Missouri? MPG problems inside | 4MPG | Fuel Economy Forum | 31 | 12-17-2008 05:48 PM |
| Toyota Yaris achieves over 84 mpg in MPG Marathon | tk-421 | Off-topic / Other Cars / Everything else Discussions | 5 | 11-17-2008 07:41 PM |
